Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
Can't tell for shure in Poser (yet) but displacement maps work with contrast between (greyscale) black and white. So I'd try to lower the contrast. If you have Photoshop, try perhaps the highpass filter. I also get the impression that the head and the body d-maps are at a different scale. I had this on an item bought at Daz' and goit a reply that normally the head/body should be set at a scale of some three as the body is usually about three times lager. Not in UV map, but in size, and the size of the uvmaps is what causes this problem.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1740708
The problem may be that with a standard greyscale map, there are only 8 bit of displacement information, that are only 256 different levels. That can be overcome with 16 bit displacement maps, but poser can not read 16 bit images directly. But there is a little trick with Photoshop and math nodes. The link shows you the necessary steps; sorry I have not yet found the time to write a proper tutorial. The original post was about z-brush generated maps, but it should be work for 16 bit maps generated in Photoshop as well.Quinlor, thanks for the link. It helped a little, but not as much as I had hoped. What I want may not be possible, since displacements maps can only go normal to the surface.
Hi stewer! You are right, Poser can read them. But it seems that the output of the image node is only 8 bit anyway. When I put my 16 bit TIFF directly into poser, I got the result shown in the first Pic at the link, the same as with a 8 bit version of the same map. With the described method I got the much better result in the second Pic.
Thankies for the help!
