Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2025 Jan 23 6:01 pm)
You could do an altitude render of the object from the water's viewpoint, use that render as a terrain, and then use it as a boolean object to cut a chunk out of the water. Bet that explanation's as clear as mud! Or, more simply, why not duplicate the object and make it into a boolean object? Then group it with the water. It might help if you stretched it a bit lengthways as well, so it seems like it's gouging a path into the water.
Message edited on: 07/19/2004 01:39
I am trying to fly an object into the water at an angle. How do I do a water displacement map when the object goes into the water? How can I make the object effect the water?
