Vue F.A.Q (Last Updated: 2025 Jan 30 6:52 am)
Have a look onto toe preferences. There you can select or deselect the automatic scaling feature. Another "trick" is to use a block that defines the whole model space for all of the parts you want to import separately. This block you then can delete - after importing the part.
I have found that the scale of models I import have been changed.
For example I made a stone block model and then a wall out of the same blocks. When I imported them (seperatly) the block was the same size as the entire wall model. I have had similar problems with Poser, although not nearly as bad.
Is there some way to force Vue and Mover to import them in scale relevent to each other?
