Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Conforming clothing: the files need to be installed into the relevant directories under /Runtime. If it's a .zip file that you've downloaded (probable), then there are several possibilities (and also you'll need winzip for the extraction): - the .zip has the paths set up correctly, starting from "Runtime". If that's the case, then just extract to your runtime directory, with "use folder names" checked. (BTW "folder" = "directory" - just in case you didn't know..) - the .zip has paths, but they don't start from "Runtime". In this case, create a temporary directory, extract the file there (again with "use folder names" checked), then use explorer to copy the files into the equivalent folders under "Runtime". - the .zip doesn't contain any paths. That's when it gets tedious; you then need to use a text-processor to work out where the files should go. However, this is fairly rare from R'osity free-stuff. Hope this helps:-) Cheers, Diolma
I've downloaded some conforming clothing from the freebie section, but I can't for the life of me figure out how to bring it into Poser 5 to use it on my Don figure. I've searched through the manual and I can't find anything specific. Secondly, does contentparadise.com actually work? When I went to the Content room in Poser it opened my browser to their site, but it was down.
