Sun, Nov 3, 6:11 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 03 10:43 am)
Subject: Weird banding on posted image.
bushi ( ) posted Fri, 24 September 2004 at 2:03 AM ยท edited Sun, 03 November 2024 at 12:25 PM
I tried adding an image to the gallery this evening but removed it. The image as displayed had these odd bands of color that didn't show in PS. It looked as though the bits/pixel had been lowered. I saved the image from the gallery and tried it in both PS and ImagePals and it looked fine. I'm sure this has come up before but can't remember how to fix it. I've dropped it in to the WIP gallery. If anyone would like to take a look and suggest a resolution it would be appreciated. The image does contain nudity so be warned.
EnglishBob ( ) posted Fri, 24 September 2004 at 4:15 AM
Couldn't find your image - can you add a link for the search impaired among us? :)
12rounds ( ) posted Fri, 24 September 2004 at 9:01 AM
Sounds like a transfer error to me. In a zip -file this would mean a checksum error, but in image files you just see the errors like that. Resolution is to delete the old one and do the process all over again. Some years back I experienced this a lot when transferring images to a crowded server over a bad modem line.
bushi ( ) posted Fri, 24 September 2004 at 12:34 PM
EB - I'm a bit hesitant to add a direct link because the image contains nudity. It's in the Work In Progress gallery and is titled "Problem Test".
12rounds - I tried that earlier but it didn't seem to make a difference. Thanks for the suggestion though.
I'm wondering if it has something to do with the way PS handles conversions from tif files to jpeg. I started with a tif image since I needed the alpha channel. In the past I've just grabbed the alpha channel and used it to mask a jpeg image in PS. This time I used the tif image that contained the alpha channel. When I finished working on the pic I exported it from PS as a jpeg. It's the only difference that I can think of between this one and others that I've uploaded. I'm going to rework image using a jpeg as the start point and see if that makes a difference.
xantor ( ) posted Fri, 24 September 2004 at 4:06 PM
I couldn`t see anything wrong with the picture.
lhiannan ( ) posted Fri, 24 September 2004 at 9:02 PM
I don't see any banding in the pic either. Maybe it is the difference between PS software and monitor software? I've had images show up brighter here than in my image editor. Does the banding appear if you load your image as a desktop image?
bushi ( ) posted Fri, 24 September 2004 at 10:15 PM
OK, feel free to slap me around on this one. I have two PCs, one that I use just for internet stuff (old PIII with 64 MG of DRAM) and an Athlon XP 2100+ for my modeling ect. The idea being that if the internet PC gets a bad virus I can just clear it off and re-build the disks. Anyway, it turns out that on the internet PC the color quality was set to Hi-Color (16 bit) rather then True-Color (32 bit). When it got set that way, I can't even guess but setting it to 32 bit mode did the trick. The thing I can't figure out is why it only showed up on this image and not on others in the galleries. Thanks to all that replied.
GladysClump ( ) posted Sat, 25 September 2004 at 1:37 AM
Let the slapping begin ;)
bushi ( ) posted Sat, 25 September 2004 at 1:59 AM
CG - Thank you sir, may I have another! :-)
GladysClump ( ) posted Sat, 25 September 2004 at 2:20 AM
Yes, you get another one just for calling me "Sir" LOL
xantor ( ) posted Sat, 25 September 2004 at 10:38 AM
At least the problem was fixed.
