Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
Click on the head,and you will find a dial for "Brows Gone". Also,when you apply Vic2 textures (which the MilliGirls use),useing a mat file....you may have a problem with the brows and/or eyelashs. Easy to fix...just open the material settings,and you will find the upper eyebrow or eyelash is listed twice. One will have the correct settings,while the other has no settings. Add the correct settings to the empty one,and then you are all set. SWAMP
OK..maybe I confused you a bit when I mentioned the double listing of eyebrows and eyelashes. What your settings should be (based on most textures for MilliGirls don't use trans-mapped brows).... EyeBrows- Object color: Same as skin (probably white). Texture Map: Head texture. Transparency Map: None. Transparency sliders: Both set to "o". UpperEyeBrows- Object color: White. Texture Map: None. Transparency Map: None. Transparency sliders: Both set to "100". SWAMP
Hi :) I've tried out (in Poser 4) the Preteen Vicki, but the eyebrows are massive and I couldn't turn them off or to 'normal' eyebrows like I could do at V3. Does anyone know if there are Brow-trans files for PT somewhere? Tranlashes were included every character oder texture but not brows. Or ain't there such transfiles? :) Thanks for help.
