Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 4:13 pm)
Yes, if the pose set contains hip translations it will move the figure out of frame. Once you apply the pose back the camera out so you can find the figure. Select it a and turn off Inverse Kinmatics, then select the hip and "zero" it's XYZ parameter dials. The figure should then move to the center of the scene. Save this Pose back to the library when you have it the way you want it. -JH.
I have 2 characters ready to go - when I load them into the document window I can't seem to scale them the same, and cannot 'get them' to pose together in combined pose presets. I select 1 of them, the other disappears, using the posing or main camera. I select the correct figure & body but no luck. I read a tip that said it's in the hips, but I can't figure out how. Does anyone have the patience to explain this or point me towards the answer? You've all answered so many questions for me through other peoples please for help. Thank you, you are all incredible! BillyGoat
