Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 23 1:52 am)
Attached Link: http://market.renderosity.com/softgood.ez?Who=Morris
These are the 2 teary head maps, one with smudgy eyeliner and lipstick, and one without.Content Advisory! This message contains nudity
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=32298
The other bonus files.I tried to create glossy looking eye textures for P4 users, I'm not sure if they really turned out the way I truly wanted them, but I kind of like the way they looked so I included them in a second expansion zip that can be found with the other bonus files ;-)
Introducing Katie, for Victoria 3 from DAZ3D, by Jennifer R Morris Johannes!To be used with Poser 4.03 and Higher
Optimized for POser 5
Well I had put V3 on the shelf for a little while as I worked on other projects, but then a friend bought me a little gift from the MarketPlace, the gorgeous photos of "Kate" by levius, and I just couldn't help myself! So Katie for V3 came to be.
I mixed photos from my own personal collection and agonized over the smallest details, then brought the textures into Poser 5 and played with node settings to try and bring out all the details of this gorgeous texture set. I think all my time paid off!
I included a MAT pose that will make the skin have a glittery effect and a MAT pose to give the skin a beautiful glow without the glittery effect. And while Katie is optimized for P5, I however made sure the textures would work in P4 or Propack, the MAT poses for P4 simply don't take advantage of bump maps or the other goodies Poser 5 has to offer.
All my store renders were done with DAZ 3d's True Global lighting.
http://secure.daz3d.com/shop.php?op=itemdetails&item=94
Some helpful tips for rendering with these textures in Poser 5, be sure to use production mode for your final render, have
"Smooth Polygons" checked, "texture filtering" UNCHECKED and "use Displacement Maps" checked, and "ray tracing checked".
Finally to completely take advantage of the displacement maps, be sure you to set your "Minimum Displacement bounds" to 1.OO in your render options window. You can adjust this if you need to depending on how much detail you want to see in your final render.
You MUST own THE Victoria 3 Base and both the head and body morph packages to properly use this package. These items can be purchased through DAZ3d.com
The MOR poses will inject the correct Morph targets and set the values to set up your Katie character. However, in order to utilize the expressions for V3, you will need to use the expression injection poses.
To install this package simply locate your Poser 4 folder, or ProPack or Poser 5, depending on what application you will be using) and unzip with "use folder options" selected, the files are already set to create and load into the proper folders.
Ok so what you get in this pack
1 Head Texture Map 4000x2719
1 Body Texture Maps 4000x5333
1 Left Eye Texture
1 Right Eye Texture
1 Head bump/displacement Map 4000x2719
1 Body bump/displacement Map 4000x5333
1 Head Glittery Bump Map 4000x2719
1 Body Glittery Bump Map 4000x5333
1 Eyelash transmap
1 Teeth & Gums Map
1 each of FACE only INJ and REM poses for V3
1 each of FACE & Body INJ and REM poses
1 MAT pose for Poser 4 for head and body textures
1 MAT pose for Head & Body OPTIMIZED for P5
1 Glittery MAT pose for P5
Also included are 2 free expansion packs, with 4 make-up head maps 4000x2719 each, 2 teary eyed head maps 4000x2719 each, 3 additional eye colors, (hazel, blue, green) and 5 additional glossy looking eye textures for P4, and MAT poses for P4 and P5 for all files.
And an additional Cutie Pie morph for V3.
Because of file limitations by Renderosity you will need to loacte the additional text file within the zip after purchase to obtain a link to get your extra textures.
