Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 8:30 pm)
Attached Link: http://housecall.trendmicro.com/
As a hyper-paranoid wannabe admin, Id look at any system change that you didnt make yourself with an arched eyebrow.If youve some time, take your system to the above link, its probably the most trusted online viri scanner available, and the only one my ISP will unreservedly advise. They havent found so much as a second that they can comfortably suggest as safe and trustworthy (gotta love yer net neighbors, huh?) EDIT: if you havent been here before, you want to click the top link of "scan your PC now" this will bring up a pop-up asking for permission to do a download. This is the definitions file of malicious code that the scanner uses to compare to your system files. Its safe and necessary to the scan, so you can safely select Yes when prompted.
Message edited on: 12/05/2004 14:29
For a couple days, the gallery pics and thumbnails wouldn't load. I cleared caches restarted etc.. solution-My date time calender was wrong.Don't know why, but it was on Jan5 2005. I set to correct date, restarted,re-freshes. everythings ok now. I wanted to post in case anyone else had this trouble in the future :o)
