Thu, Mar 12, 7:26 PM CDT
Renderosity Forums / Poser Python Scripting
Welcome to the Poser Python Scripting Forum
Forum Moderators: Lobo3433, Staff Forum Coordinators: Anim8dtoon
Poser Python Scripting F.A.Q (Last Updated: 2026 Mar 06 2:31 pm)
We now have a ProPack Section in the Poser FreeStuff.
Check out the new Poser Python Wish List thread. If you have an idea for a script, jot it down and maybe someone can write it. If you're looking to write a script, check out this thread for useful suggestions.
Also, check out the official Python site for interpreters, sample code, applications, cool links and debuggers. This is THE central site for Python.
You can now attach text files to your posts to pass around scripts. Just attach the script as a txt file like you would a jpg or gif. Since the forum will use a random name for the file in the link, you should give instructions on what the file name should be and where to install it. Its a good idea to usually put that info right in the script file as well.
Subject: Ockham's simple SaveImage script
lundon_Don ( ) posted Sat, 18 December 2004 at 9:35 AM · edited Wed, 11 March 2026 at 2:37 AM
Ockham, In the previous message you mentioned your "simple SaveImage script". I don't see it on your web site. Is it "just" a simple script you use on a day-to-day basis? I'm sure lot's of us would love to see some of your day-to-day scripts. Don
ockham ( ) posted Sat, 18 December 2004 at 4:27 PM
Okay. This is sort of hard-wired to use a standard location so that I can just click once to put an image into a known place. Then I always have Irfanview set up to start in the same folder, so I can use the magic of Irfan to view, change to JPG, copy, etc. If you want a different location, change the part with C:TEMP to whatever....
My python page
My ShareCG freebies
lundon_Don ( ) posted Sat, 18 December 2004 at 5:52 PM
Thanks. I picture you having loads of little scripts to do just about everything under the sun in Poser. Is that true? What do you think your most useful, functional scripts are? (Don't mean to be nosie- just trying to learn from the master) Don
ockham ( ) posted Sat, 18 December 2004 at 10:34 PM
What I use more than anything else is the "hold still, dammit" scripts. One for lights, one for current prop or body part, one for current figure. Each of them takes the condition at present frame, moves it back to frame 1, and removes keyframes. I use them because I always find the just-right placement for some item when I'm looking at frame 29 or 57 or so; these let me pin down the just-right setting with one click. The attached text includes all three pasted together.
My python page
My ShareCG freebies
lundon_Don ( ) posted Sat, 18 December 2004 at 10:48 PM
Thanks!
