Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:11 pm)
Great job! Do you have a detailed tutorial for the clothes conversions though? I was just trying that today, doing exactly as you outline but when I would load the new sandals (in my case) they wouldn't show up. The name showed on the drop down list below the display window but nothing in the scene. I even checked the Hierarchy window to make sure everything was visible. Also, do you make your own JP center poses (and if so, how? I've been using MAT Pose Edit and hand editing out most parts) or can we find them somewhere?
Thanks. I followed instructions posted here on the forum. Do a search for Clothing Coversion and it'll pull up the instructions. I only used Poser 4 and BBedit to my conversion of CatGirl Boots for M3. As for your sandles, that should be pretty easy to do, but if any one thing is wrong in your CR2, it will cause problems. I suggest you try reverse engineering sandles for the figure you already have. Compare the two CR2 and look for anything that doesn't match. I didn't make the JP pose, but it's shown how to do it here on the forum. You can also download JP poses here: http://www.netherforums.com/nws-utility.htm bB
