Thu, Nov 28, 2:06 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Help setting_up joint parameters
Stephen Ray ( ) posted Fri, 05 January 2001 at 6:25 PM · edited Mon, 29 July 2024 at 1:50 PM
I'm trying to make a possible unicycle prop ( figure) , I'm having a problem setting up the joint parameters for the wheel and pedals. The wheel is the parent to the pedals in the hierarchy .When I get the wheel to spin right the pedals get stretched or distorted and lose their position. When I get the pedals to spin correctly the wheel gets all distorted. Can Anyone tell me the how's and why's on setting up joint parameters or send me to a tutorial. Or give me any kind of idea how to do this. Thanks
Stephen Ray
JeffH ( ) posted Fri, 05 January 2001 at 10:12 PM
Attached Link: http://www.nerd3d.com
The easy way to do it is to turn off the bending property for the wheel and pedals. Select each part and bring up the properties for it, then uncheck the bend box. The hard way (which is what I do) is to delete the deforming channels from the cr2. There's a small tutorial doing this with eyes at www.nerd3d.com -JH.
