Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 18 10:25 pm)
Hi there. twalling, Because every prop has a different origin, they all scale differently based on height, depth and width. No one pose will ever make every hair fit. You really have to do it for each hairstyle on each figure. With one exception... All Conforming hair "figures"(not props) can usually use the same pose if they all have the same base cr2 scale parameters(which normally is based on the figure's head). Hope that info helps somehow, Anton
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
I truly appreciate the input from both of you... I only discovered Netherworks this weekend, and didn't see the hair conversions... now I grabbed 'em up... that's exactly what I was looking for! (I wish there was one on there for The Girl as well, tho....) It makes sense that the different props would have different origins, and thusly a single pose wouldn't do it... luckily, these gizmos from Netherworks makes it easy to fit the props/figures then make a morph. Thats funny if you're the same Anton that makes conforming hair... the Victoria Changing Ponytail was the first figure I converted!
Hello,
I've bought several upgrade packages (like from Firecat) where it takes a hair prop made for V3 and expands it so you can use it with Aiko, The Girl, Laura, SP, Madison, etc...
Does anybody have any guidelines on how to create such poses myself? Like "Laura's head is 78% the scale of V3, while Madison's is 68%, while The Girl is the same size, with the x scale tweaked to 110%" or the like?
And how do is there a way to make a pose for the props so they'll always 'snap' into place on the characters they're parented to?
And, (sorry for so many questions) is there a difference in doing this with hair "prop" objects as compared to hair "figure" objects?
I truly appreciate any suggestions in this department, If I have to do some 'tweaking', I'd like to get it all done in one fell swoop and never have to do it again.
