Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 9:24 am)
i can not use the injections that come with V3 from Daz3d Exactly what happens when you double-click the INJ file? You need to have V3 selected, then double-click the INJ to apply, then select the relevant part of V3 (head, body, etc) and set the new morph to a value. Sometimes you need to select another part of the body and then select the affected part again to see the new morph dial. But you must set a value to have the morph take effect. how can i use the character textures for example Alyssa Most character packs are supplied with a MAT file which will apply the textures to the figure. Make sure you have V3 selected, then double-click on the MAT file you want to apply. The texture will be added to the figure. Depending on what display mode you're using, you may not see the change until you render. Hope this helps. Karen :-)
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
i can not use the injections that come with V3 from Daz3d and how can i use the character textures for example Alyssa?
