Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 19 8:16 pm)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
Just in case you're wondering what insanity I am up to this time... these books are for this library I am working on for the animation project of a friend. I am not sure if all the detail is necessary, but it looks kinda nice. :o)
Cheers! MMessage edited on: 05/21/2005 01:32
Mind Over Matter
"If you don't mind, then it don't matter."
This is astounding work mate! You really are a glutton for punishment! This question is more a matter of curiosity than criticism so don't be offended. :) With all that detail and modelled books it's a fairly high poly scene I would think? Lots of polys are the last thing you want when animating so wouldn't some of this detail have been better acheived with normal maps and/or displacement? Baz
stu thanks for the compliment, coming from you... I am humbled that you like it. It helps that I have a few scraps of reference plans lying around here. Baz you are probably right, my friend. I'm not sure all this detail is needed for the animation, and I am positive it won't be healthy for it. The entire library is less than 25,000 polygons (in LWO format) and each vertical section of books is less than 3,000 polygons. Not too heavy, I think. And if I create them as layers per vertical section, they can then be toggled on and off in the animation as required by each shot. Cheers! M
Mind Over Matter
Mind Over Matter
Mind Over Matter
Always thought behind your work my friend! Much respect! Zeno
Zeno [LightWave] ... AUDI A3 (wip) Mitchell Library (wip) ...
Mind Over Matter
