Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
Well, For some weird reason(To save space that is!) Poser 6 figures are saved as OBZ instead of OBJ. Thats OBJ with a Zip :) That is to save space the OBJ files, which are just plain text are zipped. Unzip 'em using WinRAR or use 7-Zip(Dload from sourceforge.net, free, open-source) and you will get an OBJ. Load it into UV-Mapper and ye are done.
SnowSultan also has the UV Maps for Jessi in freestuff ;) edit Scratch That. I know that there are some somewhere in FreeStuff. Let me get a link for you ;)
Message edited on: 06/02/2005 11:41
Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Attached Link: Feia's Freestuff
;) I knew they were in there! Here's a link to Feia's Freestuff. *my apologies, lol...it usually IS SS who's got the templates ;)Sitemail | Freestuff | Craftythings | Youtube|
into a fruit salad.
Sombody aught to mention that Jessi has a mapping problem, many of her maps are out of bounds, that is UV mapped outside the normal 0 to 1.000 range. In actual practice it doesn't matter that much (except it prevented me from importing her head in Max), just be aware that is why you get the message if you bring her into UV Mapper.
Poser 6 has a Python script to uncompress the files - you don't need to unzip them with any other program. Within Poser 6 click on Window - Python Scripts to open the Python palette. Click on the Utility Funcs button and then on Uncompress Files. A window pops up with a list of the files that will be uncompressed and you can check Uncompress Geometry files and Delete original files under compression.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
I've found a head map for Jessi in Freestuff, but am really in need of a map for the body as well. I have UVMapper and tried to load Jessi to create my own map, but the file type (obz) is not recognized by UVMapper. Does anyone know how to make a map for P6 characters?
