Fri, Jan 10, 4:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: need CLOTHIM help
Dave ( ) posted Fri, 05 August 2005 at 11:21 AM ยท edited Fri, 19 July 2024 at 5:50 AM
Just purchased CLOTHIM from here at the marketplace. Got it all installed. Thought I was doing as the instructions told me, but all it does is sit there and hang when I tell it to render. I'm not on a slow machine by any means. So what am I doing wrong? David Also I tried to get the app that lets you add your own clothes and I keep getting looped around.
xoconostle ( ) posted Fri, 05 August 2005 at 12:07 PM
It sounds like something may have gone wrong at installation. I'd suggest re-installing and trying again. Are you certain that you've loaded a body texture for the clothing or tattoos to be applied to?
Dave ( ) posted Fri, 05 August 2005 at 12:23 PM
Yep. Loading a body texture was one of the first things I did. I'm leaning towards the installation issue. I installed it here at work to test it out. Work uses a virus protection software that I CAN'T disengage in order to install stuff. According to them when you install software the VP shouldn't interfere. I know for a fact that is not the case. I've had other instances where I attempted to install software that we use for work purposes that has problems with the VP running in the background. At that time I was able to exit the VP to get things going. This version I can't because it's "managed" by the folks who made the software. David
