Sun, Jan 5, 2:57 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 1:41 pm)
Subject: Miki's Bike
Jules53757 ( ) posted Fri, 26 August 2005 at 7:14 AM · edited Wed, 01 January 2025 at 11:25 AM
The Bike is a great figure with the ability to rotate both wheels together but what is the use of this if the kickstand is out. I tried a little bit around but no chance, there is a dial but it has no effect as the kickstand is obviously part of the bikebody. Even invisible doesn't work :( Maybe one has to play around with the mesh or is there an other solution known?
Ulli
Kalypso ( ) posted Fri, 26 August 2005 at 9:21 AM
Site Admin Online Now!
I haven't had the chance to see it yet but does it have a separate material? You could just max out transparency, no highlights and it should render invisible.
svdl ( ) posted Fri, 26 August 2005 at 3:56 PM
I fiddled around with the bike too. I'll look into it again, maybe some regrouping can fix the problem.
My gallery   My freestuff
DarthJ ( ) posted Sat, 27 August 2005 at 12:39 PM
Going to the Material Room in Poser 6 certainly helps : turn all colours to default (diffuse and reflection = white, highligt and ambient = black), remove all textures and set all dials to zero. Take a look at the action-shot : no kickstand. jl
Jules53757 ( ) posted Sat, 27 August 2005 at 2:57 PM
Thx, good idea, I'll try it
Ulli
