Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 13 4:12 am)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
Very interesting... any chance for a top view and some dimensions (in meters preferably)? I've done a few buildings before (you might have heard of Dystopia), so I might be able to help you out here. I can offer up a clean OBJ for freebies, but I'm afraid you'll have to uv map it and package it for Poser yourself. Cheers! M
Mind Over Matter
"If you don't mind, then it don't matter."
Hi Moe. Have I heard about Dystopia - OF COURSE, who hasn't!! I bought a couple of the sets and I also have the free ones too. I've never posted in this forum before, I always hang around the poser forum. Well, to be honest, I just now did a search on Google and came up with that same picture and it was 'signed' by an architect and has an email address. Another article found was a reference to the architect planning to build it in South America! Soooooooo I think I should delete the picture if I can figure out how and you could design the outside as you like. The detailed description is from the book mentioned by Kryon (which I own) and was used as a reference by the architect. I do hope you will think about designing the temple. I'm sure a lot of poserites would be interested in an 'authentic' model of an ancient Atlantean temple. Only the outside would be different - just like the contest they used to have for the prospective architects! ;-) ps: I will look through my 2 books for any dimensions.
Attached Link: http://www.matrixmasters.com/temple/
I guess I can't edit my first post so here is the URL for the temple picture by the architect.Thanks for the support, encouragement and vote of confidence. :o) I won't be able to copy the design shown for obvious copyright reasons, but I think I'll manage to get all the functions as described in your first post. Will you be requiring interior as well as exterior sets (modeled separately, of course)? If you can come up with more detailed dimensions and descriptions, perhaps you can email them to me at moebius87@team-dystopia.com. Cheers! M
Mind Over Matter
I was hoping to get someone to make this for me or for the marketplace. I have never come across one before. I asked in the wishing well forum also.
Atlantean Temple of Rejuvenation
THE SUPERSTRUCTURE
As you stand off at a distance and view this temple, you see a spire pointing to the sky, and a spire pointing to the earth. It is girded in the mid point and held up with 5 legs at an incline. The color is back.
The 5 legs are hollow. They are inclined to the center area where the work is done and attached there.
The first leg contains the power...running from the ground up into the apparatus.
The second leg is also hollow and contains the entrance and exit for the faciliators.
The third leg contains the entrance and exit for the priest of that day.
The fourth leg contains the entrance only for the one to be healed and rebalanced.
The fifth leg, the most important, contains the exit only of the one who has been rebalanced and healed.
(There is a spherical room (2 hemispheres) in the mid point of the spires pointing to the sky and earth and this where all the work is done. It seems that there is an elevator going up and down inside the hollow legs.)
The inner chamber sphere is contained within and supported by a structural shell building comprised of a ring of rooms and a perimeter corridor at the level of the chamber floor.
The legs are of sufficient height to allow the lower spire to clear the base of the temple.
THE SPIRES
There are 2 spires. One is mounted upright with its circular base on or above the upper chamber hemisphere. The other is suspended under the lower chamber with its circular base mounted to the lower hemisphere with the vertex pointing to the center of the earth. Both spires are in the form of perfect cones. Both are conical spires and are aligned with vertical axis of the inner chamber. Both spires have in them or on them at least 1 spiral. The angle of the spires is 72 degrees. They are affixed to and supported by the superstructure. They tangentially align.
THE BASE
The shape of the base is important for its support function and use. It must support the structure, lift the bottom spire off the ground, and also allow for the mechanized lifts. The angles and shape as drawn in the picture are generally correct. There were contests within those who built these temples for the most beautiful design - so there were variations.
At the top of the base structure, under the superstucture and within the circumference of the legs, is a sunken courtyard open to the sky and temple. The pool is very deep and is artificially illuminated to enhance what the bottom spire's engine does to it during use - it becomes a whirlpool at times. When the pool is calm the vertex of the lower spire nearly touches the surface of the water. This pool is meant to absorb and dissipate the effects of the engine's vortex. The vortex has the side effect of lifting and spinning the water slightly, as well as creating a beautiful mist.
THE INNER CHAMBER
The chamber is a sphere that is divided into 2 equal hemipheres at the horizontal plane. The floor of the chamber is mounted on, and supported by, the lower hemiphere. The entire floor of the chamber is a turntable. Within the chamber are 2 tables. One table is located on the floor and is 'centered' on the vertical axis of the chamber sphere (offset by 3 metres). This table receives the 'target' human. The table rotates about the vertical axis under the direction of the one who stands before the 'control' table. The control table is located on the floor of the chamber and off axis. On the control table are 2 small spheres located near to the edge. The control table is a circle and is permanently fixed or mounted toward the outer perimeter, always with the priest facing the center axis of the room. The target table is on a separate turntable/lift that rotates independently at different directions and velocities than the overall floor. It is raised naturally by part of a device that will remain unrevealed at this time, but that will, during ceremony, lift this table to a mid point between floor and ceiling.
There are 2 tables in this room. There are many gathered around one of the tables, putting their hands on something which will not be revealed at this time, for it is not appropriate. The 'target' human lies on the other table in the room, and 1 female facilitator stands over this person. Also within the sphere of the room there is rotation within rotation, for it is the motion which is the catalyst to the magnetics which do the polarization.
