Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Jan 26 7:30 pm)
Visit the Carrara Gallery here.
Attached Link: http://digitalcarversguild.com/index.php
You can use Eric's wonderful and indispensible ShaderOps. Of all his plugins for Carrara.... this one is THE one to have.Erics plugin is great, I really like it . There is another option to do this that comes in C4 . You select all the objects you want shaded the same , then group them together using "ctrl+G" . Then in the properties tray select the shader you want to apply to them then click the "apply to children" button . Mike
Selecting multiple objects to shade at one time, is this possible? I have a scene with multiple objects and I want to use the same shader on all of them. Is it possible to do this? Or do you have to click each ind. object with the eyedropper, or drag and drop the shader on the object? Thanks.
