Tue, Jan 7, 9:13 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 07 11:07 am)
Subject: sr2 destroyed the Girl
wheatpenny ( ) posted Wed, 16 November 2005 at 11:41 AM · edited Tue, 07 January 2025 at 9:12 PM
Site Admin
Since I installed sr2 the girl has been rendered unusable (see attatched image). Is there a way to fix it (short of uninstalling SR2). I reinstalled the girrl several times (in 3 different locations) and nothing seems to fix it.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
texboy ( ) posted Wed, 16 November 2005 at 11:55 AM
Just turn off IK on the figure's legs; scared the bejeezus out of me, too, but that's the fix.
wheatpenny ( ) posted Wed, 16 November 2005 at 12:04 PM
Site Admin
OK, thanks. That worked.
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
Casette ( ) posted Wed, 16 November 2005 at 12:08 PM
Strange... no troubles with TheGirl here... :(
CASETTE
DarthJ ( ) posted Wed, 16 November 2005 at 1:23 PM
I had this problem too when I installed "The Girl" but that was BEFORE sr2 ... I reset her foot X-Y-Z dials back to 0.00
wheatpenny ( ) posted Wed, 16 November 2005 at 1:36 PM
Site Admin
OK, well it appears to be a IK problem.
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
Puntomaus ( ) posted Wed, 16 November 2005 at 2:11 PM
I just loaded the Girl to see what happens but nope, don't have this issue. Before I loaded her I thought it might be an IK issue but she loaded fine. Zeroed her without turning off IK and she still looks fine. Tried all three Cr2s and no problem at all. But I've read somewhere else someone had this same problem in P5 - so maybe it's something completely different causing this?
Every organisation rests upon a mountain of secrets ~ Julian Assange
modus0 ( ) posted Wed, 16 November 2005 at 2:27 PM
Just loader her up in P6 SR2, no problems, she even poses properly. Although I found out I don't have any textures for her. :(
Kalypso ( ) posted Wed, 16 November 2005 at 3:31 PM
Site Admin
modus0, if you use the Girl with the V3 uv's you can use any of V3's maps and there are a lot really good free ones here too!
modus0 ( ) posted Wed, 16 November 2005 at 4:25 PM
I know, but I don't have any textures made specifically for the Girl.
mickmca ( ) posted Wed, 16 November 2005 at 4:41 PM
Interesting. I loaded the Pre-School Vickie (is that "Maddie"?) into P6SR2, and it hosed the controls on her legs. In order to "fix" it, I had to turn ON IK to fix it. I found the same problem with M2. Don't have the models at work, so I can't show results, but effectively, if you pull the foot to the side from the zero position with IK off, the foot moves, but the shin and thigh twist into a non-human pretzel configuration. Re-zero the figure and turn on IK, and the foot moves the leg just fine. I just checked, and the same thing happens, though with less mess, when I turn off S3's IK and drag her foot. And she comes in funny, squatting a bit with her weight on the balls of her feet. In her case, the effect is pretty much the same as when pulling James' foot with IK off. If you pull the shin or thigh, it works a bit better. But with VPre-School, I couldn't get any of the leg parts to respond reasonably. It boiled down to use IK or don't move the leg. Overall, I'm not having any problems with SR2 that I didn't already have. "Click to select" is still a crap shoot, for example, to the point that I generally select body parts with the dropdown menus. That doesn't seem to be a common problem, even though I have it on two radically different computers. M
nerd ( ) posted Wed, 16 November 2005 at 7:28 PM
Forum Moderator
Not a Poser bug, It's a DAZ screwed up the CR2 bug. You'd think after a year they'd fix it. Just hit restore figure that's [crtl]+[shift]+[F] and it's fixed. If you save the figure here, it will always load right. (That's all DAZ would have to do!) The absolute position of the foot (IK on) does not match the relative (IK off) in the CR2. Poser can't tell which way they intened it to look and guesses ... Wrong in this case.
It does it in every version of Poser. Don't blame SR2
wheatpenny ( ) posted Wed, 16 November 2005 at 8:10 PM
Site Admin
Well, all I know is that it worked fine last time I used it(right after P6 first came out, before SR's 1 or 2), then today it started doing this...
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
nerd ( ) posted Thu, 17 November 2005 at 2:27 AM
Forum Moderator
I just tested it in P5, again. Still broken in P5, but it must be SR2's fault. After all it is the child of Satan.
mickmca ( ) posted Thu, 17 November 2005 at 6:57 AM
If e-Frontier takes 10,000 years to release P7, I hope they add radiosity.... M
elizabyte ( ) posted Thu, 17 November 2005 at 7:10 AM
Not really. I haven't installed it. I just wanted to post a silly title. I was inspired by nerd. :-) bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
R_Hatch ( ) posted Thu, 17 November 2005 at 7:29 AM
...and then wouldn't give me extra napkins when I asked! Damnable thing.
