Wed, Nov 27, 4:40 AM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2024 Nov 26 4:28 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: Different approach to postwork
Dann-O ( ) posted Tue, 22 November 2005 at 11:15 PM · edited Fri, 22 November 2024 at 9:12 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1097307
Well here is a little bit on an approach to postwork that is a bit different. I am actually trying to give it a bit less realism. My goal is to try to get close to the look of a lot of 70's album cover art taht used to be done with ink acrylic and airbrush. So here is a veiw of the finished work. Here is a link to another example of using the same approach.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
Dann-O ( ) posted Tue, 22 November 2005 at 11:17 PM · edited Tue, 22 November 2005 at 11:18 PM
Well now we will get a look at what the render looked like before postwork.
Message edited on: 11/22/2005 23:18
Dann-O ( ) posted Tue, 22 November 2005 at 11:25 PM
Now what I do is duplicate the original image and apply a photograin and a diffuse glow to it. This is what it looks like after that. I then set the transparency to around 50 percent you should play with it to see how it looks to you. I do keep the grain level low when I apply the filters.
Dann-O ( ) posted Tue, 22 November 2005 at 11:30 PM
Now I duplicate the original again and put the layer on top. I then apply a find edges filter and then I set the satruation to zero. After I do that. I select the white area and select similar and delete. I do some adjustments with sharpen and finaly add a little blur less than 1.5 to finsihs it. this is wha tthe layer looks liek without the white area deleted. I then set the transparency to less then 50. and I get the final result up on top. Thsi is doen in an old version of Photoshop if you know yoru filters you can get simiar results in other programs.
marcfx ( ) posted Wed, 23 November 2005 at 8:18 AM
Robot ducks!!..........love the differences. Always nice to play with settings.
Smile, your dead a long time :)
Burpee ( ) posted Wed, 23 November 2005 at 8:31 AM
I asked for a tutorial on this because I loved the results. I think the effect is fabulous and extremely useful for certain applications. Dann-O, thanks for coming through with an easy to understand explanation. This is great! Nancy
jocko500 ( ) posted Sat, 26 November 2005 at 8:05 PM
doing real good on the filters
what you see is not what you know; it in your face
