Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 08 5:10 pm)
Attached Link: http://www.philc.net/WW_tutorial1.htm
errr yes it can and yes we did :)Click the Wardrobe Wizard buttons "Utilities" ----> "Figure" ----> "More" and you will see a button labeled "Copy Joint Parameters". Before using it have a look at the tutorial at the above link. Also your Wardrobe Wizard help files includes an on screen run through of how joint parameters work plus how and why to adjust them.
Hope that helps.
I don't know if it is possible for a python script to copy spherical zones from one figure to another when both figures are loaded. Here's the problem I used Wardrobe Wizard to convert a dress using the advanced feature that retains morphs and the arms do not line up. I convert again using the standard conversion and the dress will conform. Looking at both dresses shows a difference in the SZ locations. I can manually copy all of the zones from the good dress over but that is a long, laborious process. So the question is, can python do something like that and would someone write a script?
