Fri, Jan 10, 5:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: is there a python that exports all obj's
MoonRose ( ) posted Mon, 12 December 2005 at 8:23 AM ยท edited Fri, 26 July 2024 at 5:33 AM
is there one out there or can it be made? been using poser for how many years and i'm just starting to use pythons heh... so forgive me if this is common knowledge to everyone else. reason why i'm looking for one is because when i mess around in zbrush and make a full body morph, i bring in the reworked body obj into poser and then export each part...takes forever. i'm hoping there's a python out there that can export the seperate obj's to speed things up. thanks for any help
PhilC ( ) posted Mon, 12 December 2005 at 8:39 AM
Is the morphed object a static single prop or a prop containing body part groups, or a morphed figure? I was working on one that exported out each body part then used those parts as morph targets for the base figure. If your morphed object is a grouped prop then it can easily be made into a figure using the set up room. Simply apply the base figure skeleton.
So basically my answer though by a rambling rout, is ... yes most probably :)
SWAMP ( ) posted Mon, 12 December 2005 at 9:17 AM
Id also be very interested if this could be made, Phil. Specifically what is done is an .obj is imported into Poser that has been reshaped in Zbrush. (That .obj was either exported from Poser or pulled from its geometry folder) Once its imported back into Poser, using the grouping tool to spawn prop, each body part obj has to be exported back out as morph targets. That is whats so time consuming and what MoonRose is asking about. SWAMP
PhilC ( ) posted Mon, 12 December 2005 at 11:35 AM
Or to be more accurate .... yes (now) definitely ;)
MoonRose ( ) posted Mon, 12 December 2005 at 11:37 AM
yeah.. what SWAMP said :) i'm never good at explaining myself lol i'd be very happy if one could be made :D
BastBlack ( ) posted Mon, 12 December 2005 at 6:47 PM
If I understand correctly, doesn't WW do something like that, "export figure as props"? I've used it to make figure morph tagets. bB
