Tue, Nov 26, 7:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 1:43 pm)
Subject: Conforming Antlers...
Saro ( ) posted Sat, 28 January 2006 at 9:12 PM ยท edited Tue, 26 November 2024 at 7:43 PM
I am attempting to make an antler prop for V3 from the Daz Buck for personal use, but I am stuck at the moment. I've broken the antlers into two separate figures, but I am not sure how to save them so they will conform to her head again when I reload. I've got them placed where I want them, and they are parented to her head at the moment. But when I try to save them in the figure library and then bring them out and conform them, the scaling goes back up or they move to her abdominal area. Any ideas?
freyfaxi ( ) posted Sat, 28 January 2006 at 10:06 PM
I think there already is something like this in freestuff ? Do a search for 'samhain'
nickedshield ( ) posted Sat, 28 January 2006 at 10:36 PM
If they are a prop save them back to the Props Library. Make sure they are parented to the head in the postion you like. When asked to save as a smart prop answer Yes. Do it for each side. When you load them again they should go to the correct location and be parentd.
modus0 ( ) posted Sat, 28 January 2006 at 10:36 PM
Try saving them into the Prop library instead, for something like this making it a prop is better than trying to make it a figure.
xantor ( ) posted Sat, 28 January 2006 at 10:46 PM
If they are seperate objects: Export them as one object when they are parented to the head then import them with all the import settings switched off then parent the new import to the head and save in a props library as a smart prop.
Lucca ( ) posted Sat, 28 January 2006 at 10:55 PM
Attached Link: http://www.3dmenagerie.com/goodies/tut/conform.htm
Freyfaxi, Saro is doing her own thing. Anyway, Saro, I think this link should help you.
freyfaxi ( ) posted Sat, 28 January 2006 at 11:18 PM
Looks the freebie I was thinking of is gone, anyway ..
Saro ( ) posted Sat, 28 January 2006 at 11:39 PM
Hee Hee... freyfaxi- Thanks for the thought... A lot of people have probably done the same thing. I just want to figure out how it is done so I don't have to rely on everyone else's Poser skill everytime I need a prop. Thanks Lucca, that tutorial is perfect.
Lucca ( ) posted Sun, 29 January 2006 at 9:19 PM
You're welcome. :) I'm glad it helped you.
