Tue, Feb 18, 7:18 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Disappearing Mike when props parented?
gtrias ( ) posted Sun, 12 February 2006 at 4:41 PM ยท edited Tue, 10 December 2024 at 1:54 AM
Hi everyone -
I have an M3 figure with a large number of props parented to it basically to create a kind of a suit of armor. I don't know what happened but now the M3 figure underneath is invisible on the screen except for a miscellaneous leg part and the feet. I can select the individual M3 body parts from the drop down list and the general pose behavior works when I apply poses to it but I cant select M3 directly from the display to adjust the poses. When I move the parts out of the way, the M3 figure is not displayed, nor does it render except as I said, some miscellaneous leg & feet parts. When I select the M3 parts from the drop down list, the properties still say they are visible.
Your help would be appreciated!
Thanks! I should also add that I'm running Poser 4 with all the updates.
Message edited on: 02/12/2006 16:52
Peelo ( ) posted Sun, 12 February 2006 at 8:18 PM
What are the names of the props? If they are named "forearm, lCollar" etc..That might cause problems. Allso sometimes if you use "inherit bends of the parent", you run into problems. But try changin the names of the props and see what happens.
-Morbo will now introduce the candidates - Puny Human Number One, Puny Human Number Two, and Morbo's good friend Richard Nixon.
-Life can be hilariously cruel
