Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
Maybe, but to reinstall right now is more trouble than I wish to devote to teh problem at present. For all I know, the problem might be connected to a double registry key or something. About once every six to eight months, I need to reformat my hard drive and reinstall everything, and I probably fix it then.
STOP PALESTINIAN CHILD ABUSE!!!! ISLAMIC HATRED OF JEWS
"...it doesn't allow me to click any of the check boxes." This is a known problem and the solution is odd but it works. When the export dialog is open, you need to open another application, notepad, the calendar, anything. Then, if you go back to the Poser dialog, you should be able to check the boxes. You may have to go to something else a couple of times but it does work. It's also been said that if you use a .cr2 file with the morphs and transfer them with Morph Manager, the world transforms don't get copied over so you can use that technique as well. Is this an Israeli film? I find no info on it. Didn't know whether you guys had an 'art' film industry even.
Dear lmckenzie; The trick worked, Do you know to what lengths I went to try and fix this problem on my own -ever since momodot said that my Pz3's and Cr2's were unreadable? I tried reinstalling Poser 6, no dice. I disinstalled both my Posers: Pro-pack and Poser 6. I ran both disk cleanup, but also scanned and repaired using Reg Mechanic, and then reistalled Pro-Pack, but again 'no-dice'. For two days now, I've been sitting in front of my screen, feeling dispondant -If I can't save a descent morph, that what's the point of trying to create a figure. Now I'm thinking I give it another try in the morningf.
I got the world transform of the head flying off when I transfered dp's olga morph to my own Eve with Morph Manager. My idea was for him to spawn a prop of the head with the morph dialed in and the figure "zeroed" and then export that prop as the .obj to use as a morph... I thought that might eliminate the mysterious world transform? Hassles... hmm. Do you have the P6 sr.2? It made a difference on my machine. ProPack and P4 both also require their service realeases, especially for proper .obj export is my experience. The gimmic by lmckenzie I have succeded in with other programs by just cycling around with alt-TAB even if my app was the only one running. I hate Windows... why can't I delete empty folders half the time!!! Anyway, good luck.
Attached Link: http://www.jakeludington.com/ask_jake/20051018_unlocking_cannot_delete_file_or_folder_error.html
Hmm, about the only time I have problems deleting a folder might be if I have it open in another Explorer window. Shit happens though as they say. You might try this Unlocker utility. No personal experience with it but perhaps it will help :-)"Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
Thanks, I'll check it out. I have this problem frequently when deleting or moving files from a folder, after doing this I can not delete the folder they had been in. I make sure no operations are active when I recycle/delete the folder. I can delete the folder after restarting. Dunno why. More then one PC with WidowsXP Home Edition. Thanks.
The work is really showing. I think you have it but the slant of the eyes. The eys should be with the outer corner slightly bellow the inner corner on the x-axis I think (z-rot), maybe a negative "whince" morph could round the line of the lower lids. I would bring those jowl "puffs" back a bit stronger and the mouth less wide... but it is really coming along. You know the artists trick of putting the reference image next to your work and then squinting? This shows the volumes as indicated by shadow as being accurate or not. But Aside from the two comments above I think you got it. Now for the body right? Last thing: You must change that texture from that orange to a pale purplish I think.
Are you saying that she should have MORE jowls, or LESS jowl? (I think I have 'MouthPuff' value at 0.300. Should I lower it to 0.200 or raise it to 0.400? Are the wince morphs part of the NEA package? I'm a little silly right now after this marathon of dial spinning, and I can't remember. When I finally get the face done, the body's going to be REAL fun, (especially the breast and thighs -heh, heh, heh). The texture unfortunately is a given. It's Sand_Tyger's Posette Blonde from here in the Free Stuff. I'm not all that proficient with Photoshop (Understatement), and there just very many Posette compatible 'Photorealistic' textures out there. (Sand_Tyger has offered two in Free Stuff, a blonde and a brunette. The blonde looks like she spent her life sunbathing in my native Florida, and the brunette looks like she might hale from southern Arabia. Northern European they definitely are not). However, to offset this disadvantage, I tried to lighten the skin tone by raising the ambience light-darkness value from 0 to 75, you can judge the results for yourself. If you know a way to change the texture color by some means, then tell me how its done, because I could use the knowledge.
Message edited on: 03/13/2006 13:01
Message edited on: 03/13/2006 22:35
Message edited on: 03/22/2006 23:59
This is some nice work of character development that is being done here. However, did you ask for and recieve the required permissions from the owners of the copyrights of your source images to use them this way for photo-references, and basis for photoreal textures? Have you contacted the ladies who name and appearances that you are using for your characters? If so have they granted you their permissions to use them this way. And their permissions for your distributing the results of you work that is exploiting their likeness and identity?
The somnambulator has awakened!
Message edited on: 03/07/2006 03:13
