Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Dimension3D has a python script for material copying in his freestuff. If you really want it to apply all materials, you can do this by right clicking... Select all, Copy, Apply to all and then shift-click the "Remove detached Nodes" wacro to clean up the materials...
I regularly use Olivier's "ART MATERIALS vol.1: Cartoon Shaders". I work primarily in the black and white. Most often, I set every material on every object in a scene to the same Black and White material, then go through tweaking certain ones. Needless-to-say, going through each surface and setting it to the same material is very tedious. Is there a way to do this quickly with a python script? If would be even better if I could also set every material to some solid color while I am posing, then switch back to the shaders, as everything in the preview looks black while you are working. (I've tried working with wireframes for posing, but this is tough when you are working through walls you have made invisible.) Any advice or assistance you can provide is greatly appreciated! Thanks, HL
