Sat, Nov 30, 1:00 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: I'm still struggling with anything glows...
estherau ( ) posted Tue, 28 March 2006 at 2:53 AM · edited Fri, 29 November 2024 at 1:08 PM
I used the daz fire and also a jepe flame texture map. I applied AG to part of the daz campfire. But no matter how I adust the settings I see all the light in the distance and some of the light on the girl but it doesn't look like it's coming from the fire. Love esther
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Tue, 28 March 2006 at 2:58 AM
these are my settings. Love esther
plmcelligott ( ) posted Tue, 28 March 2006 at 12:33 PM
You also need to set light color to the glow channel, not light color like it shows there.
estherau ( ) posted Wed, 29 March 2006 at 6:39 AM
You mean where it says colour, select "object glow" in the assembly room under the general tab? Love esther PS when I do that everytime I render my puter crashes.
plmcelligott ( ) posted Wed, 29 March 2006 at 11:10 AM
Hmm, that's not good. But setting the color to the object glow is how you get the object to cast it's coloring as light. Another possibility is to get ride of Anything Glows and put a bulb light inside the fire. Use a fire texture as a gel. Make sure your fire object does not cast shadows.
Patrick_210 ( ) posted Wed, 29 March 2006 at 4:54 PM
In the little white box by brightness, change that color to orange. Change the range to 10 inches ( maybe little more or less depending on the=scale of the scene ). Change range falloff to 50%, seee if that looks good. Turn off the ambient light in the scene. If this doesn't solve all the problems, post another quick render.
ren_mem ( ) posted Wed, 29 March 2006 at 10:45 PM
This doesn't work with c5 fire primitives does it? I see a shadow with a color, but not really casting a light.
No need to think outside the box....
    Just make it invisible.
ren_mem ( ) posted Wed, 29 March 2006 at 11:03 PM
Here's a quick primivol example, regular fire primitives showed similiarly.
Patrick_210 ( ) posted Thu, 30 March 2006 at 7:09 AM
She's not using Carrara fire.
estherau ( ) posted Thu, 30 March 2006 at 7:42 AM
Hi, no not using carrara fire. Okay here's my render using instructions by Patrick_210 Love esther
estherau ( ) posted Thu, 30 March 2006 at 7:43 AM
What's with the lights in the background near the horizon. I'm wondering if part of the fire is under the ground and showing through those gaps or something. Love esther
Patrick_210 ( ) posted Thu, 30 March 2006 at 11:05 AM
Okay, I've only got a minute. Whatever kind of light you are using for the sun - sunlight, distant light, spot whatever. Turn it off. Then you can see how much glow is from the fire and if that is causing the weird light on the distant terrain. It looks like there is a small glow on the pants leg, maybe not. You should also make a new file, exchange the Poser figure for a small sphere and upload it here so we can figure out what's happening. It's difficult without being able to see everything that you are trying to do. gotta run.
ren_mem ( ) posted Thu, 30 March 2006 at 1:28 PM
I knew that she said a daz item, but I was curious for myself. I guess that is a no, because of the nature of the primitive.Brings up some interesting challenges with fire.
estherau ( ) posted Thu, 30 March 2006 at 6:07 PM
i turned thesunlight to zero brightness and the only oother light was a bulb behind the camera whivh i turned off but that light near the horizon won't go away love esther
Patrick_210 ( ) posted Thu, 30 March 2006 at 6:55 PM
What about the glow? Also, you aren't using the lava shader for the terrain are you?
estherau ( ) posted Thu, 30 March 2006 at 7:38 PM
the glow is black in both terrain shaders. it was one ofthe presets that came with carrara. in the assembly room color is set to light color (fastest) love esther
Patrick_210 ( ) posted Thu, 30 March 2006 at 10:02 PM
I mean the glow from the fire.
ren_mem ( ) posted Thu, 30 March 2006 at 10:55 PM
Did you try the suggestion of simplifying esther? Just using simple plane setup and objects to make sure there is nothing odd going on. The terrain shaders have anything glows(set to light color) or were you talking about the anything glows in the fire object? That light w/ terrain at the back near horizon just looks odd.Did you try using something else there?
ren_mem ( ) posted Fri, 31 March 2006 at 12:05 AM
I did a simpler scene w/ a cone and a sphere w/ anything glows set as patrick said. I had a night scene w/ no ambient no other light. I then used a replicated terrain. Depending on the camera angle I got a glow near horizon, total blackness or if the terrain was lower could see objects better. I wonder if this could be a bug or just something difficult to do. I didn't try simple or infinite plane yet.
ren_mem ( ) posted Fri, 31 March 2006 at 12:19 AM
Here is what I think is happening. If you are using a replicated terrain(autogrid) because I didn't use anything else. If I moved the objects above the grid so the light looks right the objects look like they are floating at certain angles.I changed grid numbers to smaller numbers, but it didn't help, but maybe there is a setting to alter the grid so it won't do this. It could be an unforseen problem tho.
ren_mem ( ) posted Fri, 31 March 2006 at 12:20 AM
Here is one with the horizon glow issue.
ren_mem ( ) posted Fri, 31 March 2006 at 12:38 AM
This one has a regular terrain primitive inserted under the objects that are raised to sit on top of the replicated terrain grid.
estherau ( ) posted Sun, 02 April 2006 at 5:53 AM
Yep, you not only replicated my problem but you also referred to another problem I've had where at certain camera angles, objects that are on the terrain look as though they are floating above it. Love esther
ren_mem ( ) posted Sun, 02 April 2006 at 3:19 PM
Well, hopefully that will help.I actually think this could be a bug because it doesn't sound right.It just doesn't make sense to intentionally design it that way. While, it wouldn't really matter if you never positioned anything on a replicated terrain, that would not be what you would do most of the time.I think we should report it.
ren_mem ( ) posted Sun, 02 April 2006 at 3:28 PM
In this orthographic view you can see what is really happening. It's like something that doesn't appear to be that thick is when you go to render it.So you have this whole surface above your replicated terrain at the bottom of the white box.
estherau ( ) posted Sun, 02 April 2006 at 6:06 PM
Hi, could you please report it for me, as you have a better grasp of the problem and you're more articulate. Love esther
ren_mem ( ) posted Sun, 02 April 2006 at 11:49 PM
Ok. I think I will point them here. It seems pretty well illustrated :D
ren_mem ( ) posted Mon, 03 April 2006 at 3:35 PM
I explored further, since I did this pretty quickly and found you can change the replicated terrains thickness, hotpoint and position, if needed so the terrain you are using is above the white replicated grid. This eliminates the render issues that I can see.The grid which is acting like a solid is now under the terrain. That way you don't have to insert another terrain. So it is really just a bad choice for the default settings.I did report it tho.
estherau ( ) posted Fri, 07 April 2006 at 7:21 AM
I think you've fixed my problem ren_mem, you are clever. I don't know how you ever worked it out. Just rendering it now after checking the preview. Love esther
estherau ( ) posted Fri, 07 April 2006 at 7:50 AM
Oops, I spoke too soon, that's weird - it didnt' look like that on the sample render. gosh I better go back and try again. aha I see what happened, when I made the terrains thicker the anything glows light went under the terrain. as soon as i bought it above the terrain with the rest of my objects that were sitting on the terrain, the problem recurred. Love esther
ren_mem ( ) posted Fri, 07 April 2006 at 7:34 PM
Well, thank you. Don't always feel that way :blink: After talking w/ support there isn't an issue per se, but there are some odd things that can happen. Actually better info would help in alot of this. Helps to determine if you have a bug or user error.I had a terrain go goofy today w/ the replicator. Even recreated it from scratch several times w/ basic settings. I will say that there is a box where you choose mesh instead of bounding box this seems to help with the placement of the replicated terrain and objects being placed on it. I found the smooth grid to be a problem placing objects on. Also, you can hide the original terrain, if need be.
ren_mem ( ) posted Fri, 07 April 2006 at 8:17 PM
Let me know if you got it straight or not. After playing a bit, I am understanding the replicator better. So basically, insert a terrain, then assign the replicator, then use mesh instead of bounding box to view the grid, for placing things on it. I would avoid having to insert another terrain, I would try to hide the original terrain, if that helps. I also would avoid moving the original terrain around or adjusting grid thickness etc...(even tho I mentioned that initially) Also use autogrid. My issue today I think was due to not having 0's in all the random transforms when using autogrid. Haven't spent anytime checking this out. This was good to pursue tho because i hadn't really started using the replicator much especially for terrains, so now after spending a little time with it I am using it in some other mad experiments. :biggrin:
