Forum Moderators: Wolfenshire Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Our mission is to provide an open community and unique environment where anyone interested in learning more about Adobe Photoshop can share their experience and knowledge, post their work for review and critique by their peers, and learn new techniques while developing the skills that allow each individual to realize their own unique artistic vision. We do not limit this forum to any style of work, and we strongly encourage people of all levels and interests to participate.
That Eliminate White should work in v7. I've used it many times. It's always best to start a new document with a transparent background. There are many ways to do it manually. Here is one.
Double click where it says backgound in your layers palette to change background to layer 0 (if not already a layer). Use magic wand and click on the white background of the image. Make sure your Contiguous is checked otherwise it will select all the white in your image as well. You might also need to play with your Tolerance depending on if it is a solid white. You can use the Add to Selection and Subtract from Selection. Once background is all selected then hit delete.
I should add that this method works if you have a well defined edge on your image. When you get into images with hair, grass, etc you need a new method.
Screenshot would be nice :)
Magic Wand is very useful, but Select - Color range is Magic wand on steroids. And dont forget to feather the selection with Select - Feather about 1-3% is usualy enough, depends on resolution the higher res. the higher feather radius :)
Oh forgot about transparency. Either delete the pixels or open new document but check the transparency box. Then click and drag with SHIFT holded the selection from original to new transparent document and save as .TIFF, it will save you the transparency :)
Tihomir
Open your mind and share the knowledge!
One thing I do, is to "duplicate layer", select THAT layer, AND make sure that the background layer is "invisible"... the eye icon in layers, turned off, then "Magic eraser" it using "contiguous" clicked ON... fiddling with the tolerance setting may, or may not be necessary, if there's variations... usually not. Lou.
"..... and that was when things got interestiing."
Hi I have a bit of a noob question for you guys regarding eliminating white backgrounds. I want to remove white backgrounds leaving a transparency layer. I know about the eliminate white filter but it doesnt work in v7. It seems to me there is a way to do this manually but I can't remember what it is? Any ideas?
Compact Soapy
