Fri, Jan 10, 10:04 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: How to make realistict glass material ?
Holli ( ) posted Tue, 13 June 2006 at 5:10 AM · edited Fri, 10 January 2025 at 1:34 PM
Hello,
I am looking for a tutorial or any advice how to make realistic glass in Poser 6.
Any help would be fine.
jfbeute ( ) posted Tue, 13 June 2006 at 5:26 AM
Glass is a complex material with color, transparency, reflection and refraction. All of these things are possible in Poser 5/6 but you rarely want all of them at the same time.
Please state what you want to achieve. There are already many messages about glass in this forum.
Fazzel ( ) posted Tue, 13 June 2006 at 12:24 PM
Quote - Hello,
Use the refract and reflect nodes in the material room.
Set refract to 0.7 and reflect to 0.3.
Set the color of your object  and specular to black
Make sure you have the transparency nodes set
to zero, as any transparency interfers with refraction
and reflection.
Then when you render make sure raytracing
is on in your render settings and give raytracing a value
of 4.
Then go have a hot meal because it is going to take
a long time to render.
Helgard ( ) posted Tue, 13 June 2006 at 12:39 PM
Also note that when using refract and reflect on glass, your glass must be double sided. So if it is a glass jug, there must be polygons for the outside, as well as an inner layer of polygons for the inside.  The glass must have thickness, in other words, for refraction to have the correct effect.
Your specialist military, sci-fi, historical and real world site.
Helgard ( ) posted Tue, 13 June 2006 at 1:12 PM
The mistake most people make when making buildings, cars, cockpit windows, etc, is making the glass single sided. The glass on the left is double sided, the glass on the right is single sided. You can plainly see that the refraction works better on the double sided glass.
diolma ( ) posted Tue, 13 June 2006 at 4:37 PM
Just to clarify (as in "Through a glass, clearly") a bit more...
There are two types of "double-sided".
One refers to the situation where each single polygon in the mesh "points both ways". These polygons have abosolutely no physical width. Poser (with either renderer) doesn't handle this type of mesh at all well, which incidentally makes me wonder why Poser still has the "square" prop (which is double-sided) in the primatives library - get rid of it. Only use the "Single sided square" (unless, of course, you like artifacts)..
The other type of "double sided" is where the mesh does have a physical width.
As far as glass is concerned, the mesh should have a physical width.
Hope that helps,
Cheers,
Diolma
Phantast ( ) posted Wed, 14 June 2006 at 10:25 AM
The easiest way is to render in something other than Poser. Then you can have realistic glass very easily without having to wait a long time for the render.
stewer ( ) posted Wed, 14 June 2006 at 10:51 AM
Have you tried the Glass preset materials that already come with Poser?
jamcio ( ) posted Thu, 29 June 2006 at 11:33 PM
Quote - Just to clarify (as in "Through a glass, clearly") a bit more...
Thank you so much! For someone who is dabbling in Poser for the purposes of a quick mock-up, this is one of those gotchas that can turn that "quick" mock-up into an all-day affair: - Don't use the double-sided square unless you want to spend hours rendering and re-rendering and wondering why your color maps look like crap. - The rotate and twist tools will almost never rotate things in the direction you expect or want. Much better is just to use the "direct transform" tool, which is everything those rotate tools should have been, and more. - So you're going along, happily using the direct transform tool, you do a few alterations and suddenly that helpful direct transform tool is gone. The dumb rotate and twist tools are there, but the DT tool isn't. All you know is that you have a splitting headache and you don't know how you got here. The answer? As a prank, Poser has decided to toss you into the "Materials" room (or possibly some other secret room) without your knowledge or consent. You need to click on the "Pose" tab at the top of the window to get your beloved DT tool back. - Have a couple props you're trying to group together? Don't bother trying to get the "group" tool to do anything you'd expect. What you really want is "Set Parent" -- the new parent will then control its child (unlike real life, of course). cheers, jamie
