Vue F.A.Q (Last Updated: 2025 Jan 24 7:34 pm)
You can change the exposure and contrast of your HDR file in the atmosphere editor. Place the Vue sun according to the light in your HDR ( check the shadows direction). You can also move your HDR image (offset map)in both vertical and horizontal axis , to get a nicer light on your plants or on the part you want highlighted in your render, or to make the sky higher or lower ( good for clouds).
Now about the "blotchy" shadows, I have to agree, check this link:
http://excalibur.renderosity.com/mod/gallery/index.php?image_id=1192741&member
I tried bumping up the GI quality to +1, but it didn't change anything. And nobody seems to see what I mean either!
I can't remember and since the demo stopped workin I can't check, but doesn't an HDRI create shadows from the map as well as the VueSun, in the form of leaf shadows, etc....I think I worked around it by deleting the VueSun entirely and controling the whole scene light by tweaking the environtment map...brighter, often, and more contrast seemed to help sometimes...IIRC
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Couple of ideas, if you want the blotchiness to go away, I would suggest jacking up your quality boost level for GI. Try it on a small test area and see if it doesn't work. I might also try adding a bit more of the sun in order to get some harsher shadows (set the softness of the sun to something like 3 to 5).
Lastly, I'm not sure HDRI is all that great for outdoor scenes, as the shadows are generally very soft as in an overcast sky type of setting. I would take a look at Erka's Bauhaus demo scene and see how his atmosphere is set up. I've learned a lot by studying his scenes.
best,
Chipp
Here are a few test renderings using the default sky HDRI which comes with Vue.
This first one uses absolutely no direct sunlight (Light Balance = 0%). You can see there are no real shadows to speak of.
In the second image, I've aligned the sun with the HDRI and set the Light Balance to 20%. Also, the light itself was set with a 5 degree softness factor which helps soft shadows. You can see a faint shadow on the vertical surface as well as on the ground.
The last image had the Light Balance set to 30%. The shadows are a bit more pronounced. I like it even more.
Hope this helps.
Attached Link: Here is the image and breakdown
Hey guys,I'm trying to see if I can get HDRI to produce good results on outdoor exteriors. I took the plunge and bought Dosch's HDRI skies so that I was ensured I wasn't getting bad HDRI's.
I have little to no experience with HDRI. I've been using GI on this one project and am trying for something a little more 'real'. I posted (below) an image comparing the results...and was curious if anyone can help out.
The hdri version looks blotchy, dark, and I cant tell how to place the sunlight from a particular angle. I'm guessing that the blotchiness has to do with -1.0 GI...but should I still use GI? Or up to Radiosity? Tips and help needed fellas. Help is MUCH appreciated.
I'd have more time to tweak, but the deadline is approaching fast...
-Ryan Spaulding
VueRealism.Com
