Sun, Feb 16, 8:24 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Forum Moderators: wheatpenny Forum Coordinators: Anim8dtoon
Community Center F.A.Q (Last Updated: 2025 Feb 10 11:31 pm)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: Please fix freestuff link...
PilotHigh ( ) posted Thu, 17 August 2006 at 10:40 AM · edited Sat, 15 February 2025 at 1:50 PM
FYI on the Poser Community page the freestuff link still says:
Free Stuff is currently being upgraded and will be back online at approximately 3:00PM CST.
StaceyG ( ) posted Thu, 17 August 2006 at 10:42 AM
I have alerted the programmers regarding this link.
Thank you
PilotHigh ( ) posted Mon, 21 August 2006 at 10:55 AM
Just bumping this up as it's still not fixed.
Miss Nancy ( ) posted Mon, 21 August 2006 at 1:56 PM
is that on one of the old "ez" pages? I reckon they could just delete it, but not certain.
Miss Nancy ( ) posted Mon, 21 August 2006 at 1:58 PM
PilotHigh ( ) posted Thu, 24 August 2006 at 11:59 AM
Thank you for fixing it but there's just one problem. Instead of POSER freebies it goes to ALL freebies.
hewee ( ) posted Thu, 24 August 2006 at 5:58 PM
Pick Poser or any other program add-on from the dropdown.
PilotHigh ( ) posted Fri, 25 August 2006 at 9:39 AM
hewee, that is supposed to be a poser only page!! That's why it's called the Poser Community.
hewee ( ) posted Fri, 25 August 2006 at 11:58 AM
Well if I go here to Free Stuff http://www.renderosity.com/mod/freestuff/ and it is ALL free Stuff and if you  pick Poser from the drop down and it takes me here http://www.renderosity.com/mod/freestuff/index.php?section_id=1 they are all Poser and it says...8011 results :: 334 pages on it.
http://www.renderosity.com/mod/freestuff/index.php?section_id=1&page=2
http://www.renderosity.com/mod/freestuff/index.php?section_id=1&page=3
http://www.renderosity.com/mod/freestuff/index.php?section_id=1&page=4
http://www.renderosity.com/mod/freestuff/index.php?section_id=1&page=5
And so on
StaceyG ( ) posted Mon, 28 August 2006 at 9:33 AM
The SubCommunities aren't converted yet so there may be some link problems if you go from there, I would suggest until the entire site gets converted including the SubCommunities you just get to the freestuff by the link at the top of the page and then click the area you want from there.
Thanks
hewee ( ) posted Mon, 28 August 2006 at 6:51 PM
I think the Free Stuff links are working ok unless I am missing something.
Clicking on Free Stuff you go here.
Then if you click on the 2 to go to the next page you go here.
http://www.renderosity.com/mod/freestuff/index.php?page=2
http://www.renderosity.com/mod/freestuff/index.php?page=3
etc, etc
2D takes you here.
http://www.renderosity.com/mod/freestuff/index.php?section_id=11
http://www.renderosity.com/mod/freestuff/index.php?section_id=11&page=2
DAZ/Studio takes you here.
http://www.renderosity.com/mod/freestuff/index.php?section_id=28
So for each part you pick from in the drop down your get a section_id=with a number here. Then a page number gets added when you click on another page.
So all the Free Stuff seems to be showing up ok for me on 98 with Firefox. Or all the places I checked out. I did not go tru all the ones in the drop down and check each but the one's I did look at were ok.
PilotHigh ( ) posted Tue, 29 August 2006 at 1:32 PM
hewee, we're talking about something totally different than you are. Go to Renderosity Front Page (not the store) and on the side there is a drop-down called "Communities". Click on Poser. Now everything on this page is Poser only. Click on Poser Products and it takes you to only Poser things for sale. Likewise click on Poser Forum and it takes you to that forum only. Click on Free Stuff and it should show only Poser free stuff - but it doesn't.
So...Stacy said that the community pages have not been converted to the new PHP format yet so the links are not correct. That is all I needed to know.
hewee ( ) posted Tue, 29 August 2006 at 2:21 PM
I can not even see any dropdowns on the front page or any Communities so can even try to see if it works.
I used Firefox, Netscape and IE and it is not showing up in any of them.
PilotHigh ( ) posted Thu, 31 August 2006 at 10:41 AM
Attached Link: http://camelot.renderosity.com/index.ez
hewee, use this address to go to the front page. Near the top of the page on the left or the right, depending on where your prefs are set, there are dropdown menus for:
Member Options
Communities
Renderosity info
I am also using Firefox.
SndCastie ( ) posted Thu, 31 August 2006 at 1:44 PM
Pilothigh that is the old side of the site like Stacey said you should use the link at the top of the forums for the freestuff area the subcommunity's are not converted over yet so that is why the link isn't working correctly. As Stacey said once the whole site is converted over the links will be fixed.
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
hewee ( ) posted Thu, 31 August 2006 at 9:10 PM
Thanks PilotHigh but your are using a old link that was just for the change so need to use the other links.
But thangs for the link to the older page because I was wonder what happen to the Web Ring Top 15 or the Web Ring Top links because I don't know how to get to them from the updated site because they are not listed now or hiding some place.
Do we still have the Web Ring here at the site?
SndCastie ( ) posted Fri, 01 September 2006 at 3:00 AM
Yes once it is converted over things will show up. It is still on the old side of the site. by using the link that PilotHigh has provided you can see it on the sidebar.
Sandy
