Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
What do you mean by "assign Poser's exe" to open a PZ3. You open Poser and then you go to file goto open out comes the browser menu goto the folder where your PZ3 is and click it....
If windows (not Poser) is telling you something is wrong, then you might have some corruption somewhere in the window's folder perhaps.... or some DLL out to lunch....
explain futher
The best way to assign is by using the Folder Options (in the Control Panel). Go to the File Types tab and look for PZ3. Click once on it and hit the 'Change..." button. This will allow you to assign the file type to the selected executable. To retain this association, make sure to check "Always use the selected program to open this kind of file". OK out.
With the "Advanced" option, you can be more specific by setting up commands that will be accessible in Explorer's right context menu (etc.), but this shouldn't be necessary for the default "open" command.
If the association still isn't retained, there are two possibilities:
Some other program is automatically stealing (setting) the association. Usually, it will tell you that 'some of the associated files type are associated with other programs...' in cases where the association keeps being stolen.
Corruption. The corruption could be system, munge, viral, registry (most likely). Associations are stored in the registry. If the registry is corrupt or not being saved properly, that would be cause for the association not to stick.
off.
-- Bjarne
Stroustrup
I had the same problem. My .pz3 icons looked like word pad ones or acrobat reader or something.
Install Poser 6 again, and make sure you install all of the Poser updates....SR2 and SR3.
It should work after that.
Two other threads dealing with the same issue.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2520885
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2620301
say." - Ghandi
I know how it is SUPPOSED TO WORK, but I tried that and it is not working. Once I have assigned the Poser exe to open the Poser pz3's, it just goes back to not recognizing them. I have a legal registered copy of XP Pro and Poser 6.
Free men do not ask permission to bear arms!!
