Thu, Nov 14, 10:44 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Skinvue 2 and other little problems.
WSFWARLORD ( ) posted Fri, 15 December 2006 at 8:00 AM · edited Mon, 28 October 2024 at 3:33 PM
i got a little problem with skinvue, here take a look:
http://img201.imageshack.us/img201/6417/skinvuenailproblemra8.jpg
there's a "SV2 test pattern" image that get on the nails after applying skinvue2 on my Victoria 3 poser, i also find that image on other materials of the body but thoses have no incidence on the texture.
also i always have trouble with hair color when i import a poser character, this one is supposed to be blond but her hair are much darker. how can i correct that?
dburdick ( ) posted Fri, 15 December 2006 at 11:28 AM
WSFWARLORD,
It appears that your imported fingernail material did not contain a texture map which is why the text pattern material shows up for this.  There are two ways to correct this:
  1. Go back into Poser and map the fingernail material into the body map (this is the preferred way).  Most nail materials are inside the same material that the other body materials use.  Re-import your character with the corrected nail materials nad then re-swap in SkinVue.
  2. Youn can manually load in a procedural material for the nails from the SkinVue3 material folder (e.g. SV2_Nails_Procedural).
WSFWARLORD ( ) posted Fri, 15 December 2006 at 11:32 AM
okay i'll try that, thanks ^^
