Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
What you need to do is to import it, scale and position it and then EXPORT it again with ALL checboxes unchecked.
Then import that new obj again with everything unchecked and it's the right size and right position :)
When I import an OBJ file from an existing item of clothing into Poser, the scaling is way off (it's either too big or too small) and the position is wrong (to high or too low relative to the figure). This basically makes the item useless for OBJ2CR2 as it must fit when the figure is "zeroed". I know you can adjust the scale percentage and offset on the import of the OBJ file, but this is basically trial and error; is there anyway to preserve the original scaling and position of the OBJ file from when it was a CR2? I've looked all over, but I can't seem to find any information on how to do this, so any help or pointers would be greatly appreciated.
(I posted this message at PhilC's forum as well)
The attached screenshot show what I'm talking about....after exporting the CR2 to OBJ, then reimporting the OBJ, the scale and the position of the item (in this case, the black V3 catsuit), is wrong relative to the figure.
