Mon, Feb 17, 11:08 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
Subject: Luminous Tattoos
modus0 ( ) posted Mon, 22 January 2007 at 8:26 AM · edited Thu, 13 February 2025 at 12:05 PM
I've been wondering lately, is there a way, in Poser, to make tattoos, or any other detail stuff, glow, without setting the whole material alight with Ambient glow?
For instance, the tattoos that come with Aery_Soul's Yaara (included pic with Kielo 2 morphs and Fantasy Spring outfit). Is there a way, without modifying the tattoo textures too much (or regrouping the mesh), to get those tattoos glowing in some color?
Casette ( ) posted Mon, 22 January 2007 at 8:32 AM
CASETTE
AnAardvark ( ) posted Mon, 22 January 2007 at 9:51 AM
http://www.renderosity.com/mod/tutorial/index.php?tutorial_id=518&page=1
tells you how to use node masks. You won't get actual light-emitting tatoos, but by using a reflection mask, you can get tatoos which appear to glow.
kobaltkween ( ) posted Mon, 22 January 2007 at 12:40 PM
actually, that's probably not quite how you'll want to do this.  basically, you can use a greyscale mask to do whatever you want, not just work on reflection.  so use the aery soul psd's to make a greyscale mask.  then plug the mask into ambient color that's the color you want and the strength you want.    or plug it into ambient strength.  or both.
i think reflection actually works like ambient (and alt diffuse, alt spect, etc.), but since it's meant to do something else, i'd avoid it.
note: if you're still using v3, then you can use some of the free unimesh stocking transmaps in a similar way. i have a few i acquired from here, i think.  you can hook them into the input of a blender or a color ramp node and mix them with a base texture(s), you can use them as input in math or color math node with other textures, etc.  basically, you can combine maps/materials with about as many (if not more) options as photoshop, with greyscale bitmaps functioning like layer masks.
mylemonblue ( ) posted Mon, 22 January 2007 at 5:31 PM
Content Advisory! This message contains nudity, violence
This is how it looks when I do that. I use white tatoos on black background and plug the node the image is in into the ambiance like this. (click to enlarge)
My brain is just a toy box filled with weird things
modus0 ( ) posted Mon, 22 January 2007 at 6:10 PM
So basically I'd have to invert the tattoo texture to get it to do that.
That makes sense. :biggrin:
modus0 ( ) posted Mon, 22 January 2007 at 6:52 PM
Okay, I've done a little experimenting, using the Color Math node, set to Log, and the tattoo plugged into value 1.
I didn't alter the original tattoo texture in any way, nor did I use a node mask (although I do consider than an option).
I used exactly the same scene as in my first post, only I turned Ambient on, plugged the Color Math node into it, and the tattoo texture into value 1 of the Color Math.
I was just fiddling with the Color Math node, because I figured there might be some function in it that would invert the image in Poser, and it seems the Log function helps me achieve what I wanted with minimal extra work.
modus0 ( ) posted Mon, 22 January 2007 at 6:53 PM · edited Mon, 22 January 2007 at 6:57 PM
And my material settings.
And it seems setting both values to white in the Color Math node, and using Subtract works the same.
mylemonblue ( ) posted Mon, 22 January 2007 at 7:05 PM
I didn't even think of the math functions. Cool idea. I like the way it turned out.
kobaltkween ( ) posted Mon, 22 January 2007 at 8:07 PM
just so you know, inverting is pretty simple.  take white and subtract your image.
modus0 ( ) posted Mon, 22 January 2007 at 10:38 PM
Yeah, I'm fairly proficient in the Material Room, but I've still got a looooooong way to go before I can say I'm even close to mastering it.
