Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 11:54 pm)
Choose Display->Document Style->Texture shaded from the menu.
It's in the manual too. Deeply buried, I admit, but it's there.
Have fun! Welcome to the addiction that is called Poser.
Make sure your display setings are on textured (the furthest right of the various 'balls'), rather than the simple shaded one a couple of steps to the left... sory if that's not completely clear, but my brain isfeeling a tad mashed right now...
wait a minute (rummages for manual)
Right, found it... it's the 'document displat style' button, in a line on the UI... the default setting within P5 and 6 (although they changed it in 7) is Smooth Shaded... ths uses only the diffuse colour setting for it's colouring. This is fine if you have a pink model, but if you apply a texture map, the diffuse colour node is set to white, and so your whole model goes very pale. If, however, you set the display settings to 'texture shaded', then it looks to see what, if any, texture maps are applied to a given model and displays them.
Is that any clearer? :)
jonthecelt
ok, have had poser for a while, I can use it but am not extremely familiar with it. My first Q is...How do you guys see what you are doing? When I add a texture, my model turns all white and then I have to partial render to see if I like it.
cgodyssey.com
