Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
I 'm afraid to tell you "yes" in case I'm wrong. I haven't used dynamic hair.
I would think that if you made the changes and changed the parent to be for V4 that once you saved it to the props library folder that it would load up as you have saved it and fit V4 properly.
Better wait for a second opinion on that though. I'd hate to stear you wrong.
say." - Ghandi
Hi, Nebula..
I'm also not sure of the answer (although I think that Acadia has it right), but...
Try doing what I always do: Before you commit anything, SAVE THE WHOLE SCENE AS A PZ3 FILE!
Then save the prop/hair/whatever into the library. Quit Poser.
Restart Poser, load the figure, load the hair from the library.
If it doesn't work, then something went amiss - delete the entry from the library, try an alternative approach (you still have the saved PZ3 file to start from...)
If it does work then you can delete the PZ3 file, happy in the knowledge that your save-to-library worked (although I usually wait a few days before taking that step, just in case..)
Cheers,
Diolma
Hello,
I have a dynamic hair prop that was originally made for V3. I have adjusted it to fit V4. I'd like to save it to my library. Do I just select the skullcap and add it to the library? Will it keep the adjustments I made to it (X,Y,Z data)? And if I want to use it again from the library, will it automatically fit and parent itself to V4?
Thanks!
Nebula
