Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Hi PhilC, how's everything? Wow, your Toolbox is on the table again;I hav'nt needed it yet, but I've seen it recommend dozens of time!
WIll the "Save MTs for Distribution," actually make a folder of Morph.OBJs, respective to each part the're from?
Will the script "1a) import morphed OBJ" the contents of that folder?
There are actually two ways to auto export each body part. One as a regular OBJ file, the other as just the vertex data. If redistribution is not an issue it will not make any difference which you use.
Yes you can auto load morphs from these files.
There are also other options for transferring morphs. Pick the one that best suits your work flow.
Is there a script to export a Morph.OBJ, for each Part of a Figure, like the image above?
I know SVDL has Spawcharacter.PY, but it does'nt always work.
Whenever I've really needed to work with morphs, I've always needed to EXport/Import by hand.
LIke when I want to strip a 250 V3.CR2, to about 12.5MBs, for Print Rendering:
1.) First I export all the .OBJs.
2.) I run Ockham's ZeroMorphs.py.
3.) Then I run SVDL's Removemorphs.py
This really guts a .CR2 down to like nothing.
4.) Subsequently Importing and all those Morph.OBJs, and setting them to one, then resores the original shape %100!
Importing is much easier than Exporting; but any script to automate the Importing, as well, would be even more greatly appreciated!
Currently I'm trying to figure out how to get the V4 ++Morphs.CR2's morphs, over into the V4.1 Muscle Morphs.CR2. There are no compatible INJs, and Morph Manager failed. But Importing/Exporting the .OBJ has tried true again...
