Sat, Feb 8, 6:18 PM CST
Vue F.A.Q (Last Updated: 2025 Jan 30 6:52 am)
Subject: Looping wind effects on plants?
Bettie ( ) posted Wed, 06 June 2007 at 4:20 PM · edited Sun, 02 February 2025 at 8:47 AM
Is there anyway to loop a wind animation?  I know all you have to do to achieve wind is set the animation end time, but this doesn't create any keyframes that I can tween...or does it?  Anybody have any ideas other than easing in/out in After Effects?
Thanks again!
bruno021 ( ) posted Sat, 09 June 2007 at 1:56 AM
Well, if you drag the wind arrow at a non zero time, you should see awind keyframe in the timeline, so you could play with the wind parameter a bit, and reset it to zero wind before the end of the animation, so the geometry could get back into it's original shape at the end of the animation. Problem is I don't know how long it takes to get back to normal, and there's the breeze problem too. Breeze is either on or off, and you cannot act upon it, other than the breeze parameters in the wind tab of the atmosphere editor.
Maybe you could get away with it with the animation wizard. Select your tree, open the wizard, select a "loop" animation, without animating anything, and close the wizard. Then do as above and see if it really loops ( ease in/out) the whole thing.
Phoul ( ) posted Sun, 10 June 2007 at 6:25 PM · edited Sun, 10 June 2007 at 6:30 PM
Attached Link: Looping_wind_effects_on_plant.zip [ limited time ]
Hi all,
Also here an idea...
try animate wind through atmo tab.
A key at start and a key at end with different values,
then load/edit smooth pendular filter.
Feel free to open the vue infinite scene added (see link) to figure out the trick.
Hope that help.
Regards.
Philippe Bouyer
www.belino.net
bruno021 ( ) posted Mon, 11 June 2007 at 3:22 AM
Hey, thanks, Phoul!
Bettie ( ) posted Mon, 11 June 2007 at 9:14 AM
Thanks guys!  I'll give that a shot today.
chippwalters ( ) posted Mon, 11 June 2007 at 10:52 PM
Thanks Phillipe...very nice.
Phoul ( ) posted Fri, 15 June 2007 at 7:12 PM
You're welcome. My pleasure.
Philippe Bouyer
www.belino.net
megalodon ( ) posted Wed, 20 June 2007 at 7:35 PM
Is this scene not available any more? I get an error message.
