Tue, Feb 18, 12:17 AM CST
Renderosity Forums / MarketPlace Showcase
Welcome to the MarketPlace Showcase Forum
Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 17 3:50 pm)
Welcome to the MarketPlace Showcase Forum. The Showcase Forum and Gallery are intended for all commercial related postings by active Renderosity MarketPlace Vendors only. This is a highlight area where our membership is invited to review in greater detail the various art products, software and resource site subscriptions available for purchase in the Renderosity MarketPlace.
Subject: Hot Air Rising - Desert Heat aka the Chernobyl effect
staigermanus ( ) posted Sun, 17 June 2007 at 9:49 AM · edited Thu, 11 July 2024 at 3:28 AM
Here's a tutorial in the making, using the new Animated Swap feature of PD Pro 4.1, to simulate the distortion effect of hot air rising (can also be used for underwater effects)
http://thebest3d.com/pdpro/tutorials/animswap/index.html
In a nutshell, the displacement map DWA was created byvertically
flipping an animation containing snowfall. Lots of snowfall, to the
point where you don't see or recognize a few distinct snow flakes.
Instead, it's a whole 'wall' of particles moving like through rush
hour. Large flakes, lots of them. And not too much contrast either
unless you want it crazy distorted.
I also used an alpha channel with progressive transition (linear alpha
fader) so the amount of distortion is stronger up high and down low.
As a result and side effect, when the camera moves sideways fast and
you see the edge of the sand dune go from high to low along the slope,
you see a ghost image, like double-vision. Not intended, but actually
a neat effect when you want to convey the looks and feels of
fata-morganas and you're about to collapse from this desert heat.
Welcome to Death Valley ;-) this works well also for inside a nuclear reactor when hot water rises just as it's going 'Chernobyl'
-Philip
staigermanus ( ) posted Sat, 23 June 2007 at 9:26 AM
Attached Link: http://thebest3d.com/pdpro/tutorials/animswap/camel-and-desert.swf
The tutorial is now complete - all 8 parts posted. I've also added another animation with a camel and desert view.
Also has step7 adding lens flares, and step 8 on cropping the video and resizing/resampling to usable size for compression codecs when saving to AVI
