Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
It looks as if there is a light to the left and rear of the figure. So if the camera is also to her left, you're not going to get any backlighting, unless there's a corresponding backlight on her right side.
I think...
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Storm there is some rather bad incorrect shadow offset going on there. It's most evident in the right side image, along the jawline and under the left breast.
storm,
The strong reflection from the rim light is dependent on camera position, because it just so in real life!
This is called the Fresnel effect. When light strikes skin (and many other materials) at a low glancing angle, it is almost perfectly reflected. If you put the camera in line with that reflection, then it shines very brightly. On the other hand if you're looking right at the surface that is doing the glancing reflection, then none of that light is reaching you.
Hold your hand straight out in front of you, with your palm flat, and your fingers pointing straight at a bright light. Now look at your palm. You'll see lots of specular reflection. Now keeping your fingers still pointing at the light, retrieve your hand so that you can look straight at the flat of your palm (you should have tu move and turn your head for this maneuver). At this point, your palm will be showing zero reflection from that light.
Try the same trick with the lens of your watch. Get a book or newspaper or magazine with some black text on white paper. Lay this on a table in front of you. Now hold your watch on its edge against the paper, so that a hand at 9 oclock is pointing straight down at the text. Stand over it so that the crystal is only a sliver - you should be able to see the writing reflected in the crystal with perfect clarity. Now get your head low and look right at the watch face. You will hardly see any reflection of the writing at all.
bagginsbill - Thanks for the info. But this is why I was confused. You see I understand a little about the relection of light at low angles. I suppose another example to yours would be like you can look through a window & not see much reflection because you're looking straight on, but if you view it at a low angle then there would be alot of reflection. It just seems the angle of the camera compared to the the light here in the second picture doesn't seem to be low enough for the effect here to be this great compared to the first picture. I quess I was wrong though.
Many thanks.
