Mon, Feb 10, 4:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 10:34 am)
Subject: Please Help...I did something...I don't know what.
beos53 ( ) posted Tue, 18 September 2007 at 9:20 PM · edited Tue, 30 July 2024 at 6:01 AM
I created an elf for Aiko, then saved the head as a morph only Then applied it to Laura and when I moved the morph dial to 1 this happened, when i put the dial back to 0 Laura's head is normal again Is there a way to correct this??? I know how to fix the eyes, but how do I get the head back to the propper place Thank You Steve
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
Miss Nancy ( ) posted Tue, 18 September 2007 at 10:22 PM
try "restore element" (head). in what software, and using what method, didja create the morph?
beos53 ( ) posted Tue, 18 September 2007 at 10:32 PM
I created the morph in Poser and just moved the dials
I tried restore head and it went back to Laura's head
Steve
pjz99 ( ) posted Tue, 18 September 2007 at 11:38 PM · edited Tue, 18 September 2007 at 11:39 PM
At some stage of exporting the morph, chances are you did not unselect "no world transformations", given that you're doing everything entirely within Poser.  Given that your elf is evidentally much taller than (correction) Laura's default, the points of the head are trying to move up to the elf size when you apply the morph.
My Freebies
kawecki ( ) posted Wed, 19 September 2007 at 1:43 AM
Nice Alien!
Stupidity also evolves!
beos53 ( ) posted Wed, 19 September 2007 at 6:44 PM
I thank everyone for their comments so far
pjz99:
when I exported the head I tried every combination possible either checked or unchecked
everything turned out the same way when I applied the morph.
I even tried "Shapeshifter" which  put the original Aiko head on Laura, but when I tried the morph it did the same thing.
Is there any way I could edit the cr2 to stop this and if so How?
Thank You Steve
Miss Nancy ( ) posted Wed, 19 September 2007 at 8:01 PM · edited Wed, 19 September 2007 at 8:01 PM
yeah, I reckon the problem started when ya exported the morph, which included the y-displacement. in the old days we would try to fix this by matching the body sizes and positions of the two figures, as with making conforming clothes fit a figure for which they weren't designed. but I don't have laura or even know what it is, so I can't be sure. was that a freebie somewhere?
pjz99 ( ) posted Thu, 20 September 2007 at 12:53 AM
pjz99 ( ) posted Thu, 20 September 2007 at 12:56 AM
I don't have any other suggestions for you except maybe to try asking in the DAZ forums.
My Freebies
beos53 ( ) posted Thu, 20 September 2007 at 8:52 AM
Thank you for your help
I decided not to use Laura, I am in the process of redshaping parts of Aiko to get the size of body I want.
Thanks again
Steve
TrekkieGrrrl ( ) posted Thu, 20 September 2007 at 10:02 AM
The easiest way to fix this is to import the morphed head as an obj, align it with Laura's head (as close as possible) and export the obj again, with everything unchecked. Then load the morphtarget again from the newly exported obj. That should fix it :o)
It's annoying as heck when this happens :o) I once lost my best Snape morph this way because I'd tilted his head just a little (and I had to give up realigning it)
beos53 ( ) posted Thu, 20 September 2007 at 11:50 AM
TrekkieGrrrl
That worked Fantastic...Thank You
