Bryce F.A.Q (Last Updated: 2025 Feb 17 1:22 pm)
another thing is you can go into the Deeply Thaumatalurgical Editor (DTE), and play with the styles of formatting in the material. Often, I use 'World Cubic', which will shrink the design, up the memory usage, but give a more 'detailed' look to the McGuffin I'm working with. It even works with UVMapped textures (at least from Wings)
You have in the editor a method to shrink or enlarge a mat.. no need to full around with th object file... what might help a lot.. is to at least UV map the obj file to get the mat to fit evenly...
You put the little marble thingie for bump into one of the slots (A,B,C, or D) and apply the image bump map to that slot in the material editor ->
Click the little 'P' (Image Texture) over on the texture editor, click the button that says "Texture Source Editor". You will see three windows. The first window is the texture window, the second one is the alpha (for bump, ref., trans., etc.), the third is the combination. Load your texture into the the first window, load the bump map into the second window.
You can also use those in seperate channels (A & B, for instance) and have a little more control. If a channel is being used for bump only, then just load a bump map into the second window and leave the first window blank.
Use 'Parametric' to fit the image to a UV Map.
Use 'Parametric Scaled' to tile w/ the uv mapping.
EDIT - You can use the other mapping modes (Top, Object Space, etc.) with images too.
Friends don't let friends use booleans.
For procedural textures, you increase the x,y, and z percentage sizes to make the texture tile more often; thereby making it seemlingly smaller. You can stretch and squish procedurals differently on different axis. You can also rotate and offset them.
'Transformation Tools' Button.
If you go into 'Texture Source Editor' while in procedural mode, you enter the DTE Zone :)
That's a whole new world and a very powerful procedural texture generator in it's own right.
I have some trees in obj format and want to use Bryce 'treetrunk' mats, but they render in low resolution????
