Mon, Nov 25, 7:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 8:11 pm)
Subject: In search of lightning materials
modus0 ( ) posted Tue, 13 November 2007 at 11:23 AM · edited Sun, 24 November 2024 at 8:32 PM
I'm currently working on a project that is going to need lightning, and while I have several props I can use, none of them look like lightning, and despite being somewhat proficient in the Material room, I can't seem to replicate the extreme "fuzziness" at the edges of lightning that's seen in most photographs.
So I'm wondering if any of the Material room gurus, or anyone else, has found a non-postwork mens of getting that realistic lightning look within Poser.
I've even tried using some of the materials from posework's Particles 3, and haven't gotten anything satisfactory.
Porthos ( ) posted Tue, 13 November 2007 at 12:59 PM
I did this one using a one sided square prop. I plugged the lighting map into the diffuse and ambient  colour nodes, and added a transmap in to the transparancy node!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
Porthos ( ) posted Tue, 13 November 2007 at 1:03 PM
I changed the ambient colour to alter the colour of the lightning! :)
Acadia ( ) posted Tue, 13 November 2007 at 4:19 PM
Quote - I did this one using a one sided square prop. I plugged the lighting map into the diffuse and ambient  colour nodes, and added a transmap in to the transparancy node!
Where did you get the lightning map?
Porthos ( ) posted Tue, 13 November 2007 at 4:29 PM
Hi Acadia! I created it in PSP using KPT lighnting plugin. I saved it as a jpg! :)
Acadia ( ) posted Tue, 13 November 2007 at 4:49 PM
Interesting! I do have that plugin but tend to forget about it.
I'll have to give that a try. Wonderful tip! Thanks :)
Porthos ( ) posted Tue, 13 November 2007 at 5:19 PM
You're welcome! :)
modus0 ( ) posted Tue, 13 November 2007 at 6:12 PM
Not entirely sure that'd work for me, mostly due to not having PSP.
Porthos ( ) posted Tue, 13 November 2007 at 6:17 PM
It should work the same in any graphics programme, such as Photoshop etc. :)
Acadia ( ) posted Tue, 13 November 2007 at 6:24 PM
Are you sure you connected it to the "ambient colour node"?  When I connect it to the "diffuse" and the "ambient colour", this is what I get.
Acadia ( ) posted Tue, 13 November 2007 at 6:25 PM · edited Tue, 13 November 2007 at 6:25 PM
If I connect it to the Diffuse Colour and Specular  Colour, this is what I get.
Click picture for a better view.
modus0 ( ) posted Tue, 13 November 2007 at 6:25 PM · edited Tue, 13 November 2007 at 6:27 PM
I'll have to look into it then.
Edit: It's a no-go, unless there's a free version, I don't have any spare cash laying around.
Here is the material room for the last render
Acadia ( ) posted Tue, 13 November 2007 at 6:27 PM
Quote - Not entirely sure that'd work for me, mostly due to not having PSP.
I could make you some lightning images and transmaps if you don't have the lightning plugin.  You're welcome to the 3 I've made.  Send me your email address by site mail and I'll forward them to you.
modus0 ( ) posted Tue, 13 November 2007 at 6:29 PM
Will do, thanks.
MatrixWorkz ( ) posted Tue, 13 November 2007 at 10:46 PM
I did the following image with an image of the lightening from one of those lightening balls you buy at Spencer's Gifts.
My Freebies
MatrixWorkz ( ) posted Tue, 13 November 2007 at 10:47 PM · edited Tue, 13 November 2007 at 10:49 PM
Here's the settings I used. The material was applied to two enlongated Poser Spheres.
My Freebies
Porthos ( ) posted Wed, 14 November 2007 at 4:07 AM
Here is my settings. You can alter the colour of the bolt by changing the ambient colour, which is currently white! :)
Acadia ( ) posted Wed, 14 November 2007 at 4:17 AM
Thanks for that :)
raven ( ) posted Sat, 17 November 2007 at 4:10 PM
Online Now!
Attached Link: Almathera free plugins
Here you go, a free lightning plugin (and a couple of others too).
