Mon, Feb 10, 4:42 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 10:34 am)
Subject: Transfer figure settings to a magnet?
beos53 ( ) posted Tue, 13 November 2007 at 2:28 PM · edited Fri, 09 August 2024 at 10:47 PM
I created a dress with PhilC clothing, then created a magnet to deform the chest area to get rid of the gap between the breast. everything was going fine...
created a new prop and saved it...started to save the mag. and Poser shut down.
I lost the magnet I had made!
It took a while to create the mag ( I am not very good at them)
Is there any way to transfer any setting from the prop I made to a new magnet?
I read something about changing the material zone into a magnetic zone (I don't remember whereI read it)...is this the same thing that I am asking?
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
geep ( ) posted Tue, 13 November 2007 at 3:22 PM · edited Tue, 13 November 2007 at 3:27 PM
Hi beos53,
The short answer to your question is ...... No, but you CAN ... try this ...
After deforming the object with a magnet ...
  1. Select the (deformed) object or body part
2.Use the [menu] "Object" >>> **"Spawn Morph Target"
... (Note - To use the Morph Target (MT) - Do tthe following AFTER you have done Step #3 below )
... (locate the "Morph" on the object's (or body part's) parameter dials and)
... (change it to 1.000 to recreate the original effect that you had with the magnet)
**3. Select (any part of) the magnet and delete it
  1. (re)Save the Figure (or object) and INCLUDE *Morph Targets
  • And that's all there is to it.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
PhilC ( ) posted Tue, 13 November 2007 at 4:21 PM
Grasping at straws try looking in:-
C:Documents and SettingsAdministratorLocal SettingsTempPoser 7PoserUndoCache
and copy out all the files into a temporary Poser library folder. CR2's to figures, PP2's to props.
Then load each one into Poser and see if the 3D gods are smiling on you.
Good luck.
geep ( ) posted Tue, 13 November 2007 at 4:51 PM
Good one Phil ... and, sometimes one gets lucky and those "straws" do work.
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley ( ) posted Tue, 13 November 2007 at 5:49 PM
Quote: "4. (re)Save the Figure (or object) and INCLUDE Morph Targets"
Is this somthing new in P7? In other versions of Poser 'Include morph channels..." is only an option when saving a pose, figures automaticly include morph targets when saved.
geep ( ) posted Tue, 13 November 2007 at 8:47 PM
Hi les,
Yes, I stand corrected and your statements in the above post are correct.
My apologies and ... Thanks for pointing that out.
Forgive me, it must be the Oldtimers disease setting in ..... again.
Ye olde memory ain't what she used to be.
cheers,
dr geep <---------------------- having more NSG moments than he cares to admit
cheers,
dr geep ... :o]
edited 10/5/2019
Miss Nancy ( ) posted Tue, 13 November 2007 at 10:39 PM
o.k. phil, thx fr the tip. shall hafta see where that is in tiger/leopard.
PhilC ( ) posted Tue, 13 November 2007 at 10:43 PM
You'll see the path in EditGeneral PreferencesMisc.
beos53 ( ) posted Wed, 14 November 2007 at 12:32 AM
Thanks for all the infor.
Phic that didn't help, I guess I will have to keep trying with a new magnet
and thanks for the tip
