Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Quote - "There was a problem during rendering. You can reduce rendering memory usage by lowering the maximum texture size, turning off texture filtering or using smaller bucket size."
Ahhh Yes! the dreaded not enough memory to render message.
First of all to save yourself reworking things over and over, always do a File/Save before you render. Get into habbit of doing that without exception so that when you do encounter this problem all you have to do is close poser, reopen it again and then browse to your ready to render .pz3 file. In order to get your file to render, you may have to do one, some or all of the following:
2. Reduce rendering bucket size to something smaller....64, 32, 16, or even 8. If that doesn't fix it...
3, Make parts of the cene invisible using the Heirarchy Window or the Parameter Dials Properties. Render what is left visible. Save it as a .png file. Hide what you just rendered and make some other things visible and render that. Save that render as a .png file. Keep doing that until you get all parts rendered. Open your graphic program and reassemble all of your renders into one image. If that doesn't help...
4. Browse to the folders that contains the textures you are trying to use. Make a copy of these texture files to keep somewhere save (because you are going to be overwriting the files in that particular texture folder in the next step). Make sure you account for the texure files for everything in your scene...hair textures, skin textures, clothing textures, prop textures.... it all adds up and eats up memory.
You may still have to render in pieces and lower the bucket size even after resizing the textures.
6 You can force XP to give Poser more memory (provided you have it to give). See these threads:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2516735
http://www.keindesign.de/stefan/poser/3gb.html
say." - Ghandi
Using Poser 6.0.3 I have a fustrating problem suddentley.
When rendering I get the message;
I'm using P4 rendering with Anti-alias, bump maps and texture maps.
I then rename the tex, resize (compress), make new nodes and try again.
When one texture works another one dosent.
It seems to be only on two texture areas the problem is.
