Thu, Nov 7, 8:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 8:05 am)
Subject: Clothes for V4
sidossa ( ) posted Tue, 26 February 2008 at 10:10 AM · edited Thu, 07 November 2024 at 8:34 AM
I have made a dress in 3dsmax  for a V4 character and import it in Poser7. Had to change the size and position so it fits right without any parts poking through. In the cloth room the simulation worked fine, the dress lay on character nicely and I set the V4 chracter as parent, but the dress does not do anything when V4 charater change poses (the character goes right through it).
Could someone please help me.
Thank you
wisq ( ) posted Tue, 26 February 2008 at 10:14 AM
Hi
If you change poses, you must re-run the simulation.
sidossa ( ) posted Tue, 26 February 2008 at 10:36 AM · edited Tue, 26 February 2008 at 10:36 AM
My question is how can I make the dress into a Smart prop.
Thank you
wisq ( ) posted Tue, 26 February 2008 at 10:55 AM
Quote - My question is how can I make the dress into a Smart prop.
Thank you
Go to your props library and click +
In the popup, give the dress a name and click Select Subset. Select your dress and click ok.
Click ok to save the dress as a prop.
Make sure you save the dress in a zero pose (first animation frame)
Next time you want to use it, just add the prop and set up a simulation.
svdl ( ) posted Tue, 26 February 2008 at 12:15 PM
As far as I know, when you use the Select Subset option, the dress will NOT be saved as a smart prop.
Here's how I do it: I select the dress from the actor selection dropdown, and then save it to the Props library. Poser then asks if I want to save as a smart prop.
My gallery   My freestuff
MegaJax ( ) posted Tue, 26 February 2008 at 6:39 PM
If you want the dress to move as you pose V4 you will need to convert the dress from a prop/dynamic cloth to a conforming figure.
