Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 08 5:10 pm)
The script is called only once from a pz2 file, if you put the Python call in the second part of the pose.
Use the following as pz2:
version
number 6
version
number 6
runPythonScript ":Runtime:Python:poserScripts:Test.py"
Dimension 3D - Poser Tools, Poser Props and Morphs, Cinema 4D
Plugins, and more
Renderosity Store / D3D Web Site
Quote - The script is called only once from a pz2 file, if you put the Python call in the second part of the pose.
version
number 6
version
number 6
Many thanks. That works perfectly. How in the heck did you ever figure that one out? Anyways, thanks again
Actually, it was just luck. I tried a few things to see whether it will have any influence on this behavior.
I just wonder if this is intended behavior or a Poser bug. It looks as if poses are always applied twice, readScript calls in a pose are also executed twice.
Plugins, and more
It seems that when using the runPythonScript command in a .pz2 file it will run the called python script twice. Quick example:
The .pz2 file contains:
version
number 6
The Test.py program contains:
print "Hello World"
When running this, it will print "Hello World" twice. If I invoke the script from material file (e.g. test.mt5), it runs correctly and prints only once. Any ideas on how to get the runPythonScript command to execute only once from a .PZ2?
